5.3 @ 8psi. Which fuel pump?
Old Dec 29, 2013 | 03:50 PM
  #21
Ferocity02's Avatar
I'm running a 255 on stock wiring up to 12psi normally, but it's seen 14psi. But I am also injecting water/meth. It has worked fine thus far but I suspect the pump is nearly maxed out. Next will be a 400 with upgraded wiring.
Old Dec 29, 2013 | 04:02 PM
  #22
oakley6575's Avatar
I'm still running a 255 with a hot wire kit in my turbo truck up to 11psi. I just noticed in a go pro vid I took a few days ago that I'm loosing fuel pressure at WOT. I'm guessing that I'm floating right around 550rwhp.
Old Dec 29, 2013 | 04:08 PM
  #23
blownescalade62's Avatar
When I was running 8psi with my flex pump I was OK. But running 11-12psi I'm running out of pump fuel pressure drops at Wot pulls. The Flex pump is rated @ 290GPH.
Old Dec 29, 2013 | 04:48 PM
  #24
Fast 5.3's Avatar
Registered User
what are you last two guys using for injectors?
Old Dec 29, 2013 | 04:57 PM
  #25
oakley6575's Avatar
I'm running FIC 850cc injectors.
Old Dec 29, 2013 | 04:58 PM
  #26
mine are 60#
Old Dec 29, 2013 | 06:49 PM
  #27
black4.8's Avatar
I run 60# injectors. After 500rwhp pressure starts dropping pretty bad. Been using 255 for 3 yrs. Never had any problems. Been over 600rwhp for past yr. Just keep adding Meth nozzles.lol
Old Dec 30, 2013 | 05:03 PM
  #28
Fast 5.3's Avatar
Registered User
well this is good to hear. i think im gonna go with the aem 320 just so i have room to grow, and it looks pretty fair priced. definitely gonna go with a meth system too just to help with detonation and get a little more out of tuning. Thanks for the info!
Old Dec 30, 2013 | 05:18 PM
  #29
03sierraslt's Avatar
Keep us updated on what you think of the aem320, I have not seem them used much as they are new and I have been curious about them.
Old Dec 30, 2013 | 05:23 PM
  #30
Fast 5.3's Avatar
Registered User
will do
5.3Okasai
Mar 9, 2022 01:07 PM
wrb002
Aug 31, 2015 12:00 PM
MS3Z
Jul 30, 2015 06:17 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
