milled heads with 76mm
Old Jan 1, 2014 | 12:13 AM
bluebommer07's Avatar
Default milled heads with 76mm
I'm trying to finalize my parts list many may know I'm building a 370 block with 212218 cam -3.2 forged pistons.. with those pistons and 243 heads untouched I should be around 10.4-10.6 well I have found some 243 but the owner had them milled but milled just enough to get a smooth surface, my question is would that affect the cr that much to where I have to run a different piston to stay at least 10.1 my goals are to have enough compression so out of boost it can still roll but in boost it shines.
Old Jan 1, 2014 | 08:21 AM
LS1TRUCKGUY's Avatar
Depends on how much "just enough to get a smooth surface" is. If all that needs to come off the heads is like .005, then there shouldn't be an issue. You could always make up for it with a thicker head gasket.
Old Jan 1, 2014 | 09:21 AM
Razor's Avatar
BMF
Engine Compression Ratio (CR) Calculator
What fuel are you going to run? The stock LS3 is 10.7 : 1, no issues with the Gen5 guys going FI.
I am right around 10.6:1 with a Whipple but on E85.
Old Jan 1, 2014 | 12:08 PM
heads were milled .005 no more than .006
Old Jan 1, 2014 | 12:09 PM
I will be running pump gas with meth
Old Jan 1, 2014 | 02:08 PM
oakley6575's Avatar
You will just have to measure everything when you do your pre assembly to know for sure.
03regcab sierra
Sep 9, 2015 02:02 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
lxcoupe
Aug 26, 2015 07:24 PM
darnie
Aug 10, 2015 10:25 AM
