408 roots blower build
Old Sep 9, 2011 | 11:46 PM
  #91
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Sounds freakin awesome, we need videos
Old Sep 10, 2011 | 10:21 AM
  #92
black00chev's Avatar
Slowest turbo build ever!
Old Sep 10, 2011 | 10:45 AM
  #93
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by deion82
Got the issue resolved and got it running. Had to leave town for a wedding. So shooting for Sunday to dyno now. Confirmed the current setup is 10psi boost. So other set up should be 17psi. Just running it steady at 2,600 rpm it started building ice on the injector hat and blower was cold to the touch. Have to love e85 and methanol for that.
nice,
With too much ice build up the butterflys could stick on u. Got to love ethanol.
Old Sep 11, 2011 | 08:22 PM
  #94
deion82's Avatar
Well i have a kick *** looking engine atleast. Well the engine didn't make near as much as i thought. With the roots blower i knew it wouldn't be a power horse but i'm not impressed much. Anyways here's the results.
6 lbs boost 25* timing 9.0 A/F ratio 88degrees AIT start to finish of pull= 705.2HP@6,500rpm 664.4TQ @4,700 rpm.
9 lbs boost 23* timing 8.5 A/F ratio 126 degrees start and 162degrees AIT end of pull= 732.5HP@6,100rpm 667.5TQ @5,200 rpm.
15lbs boost 17* timing 8.0 A/F ratio 183 degrees start and 209 degrees AIT end of pull= 722.9Hp@6,300rpm 678.3TQ @ 4,600 rpm.
Any input or suggestions? I have tomorrow morning yet to dyno if needed. I'll try to post dyno sheets and videos soon.
Old Sep 11, 2011 | 08:36 PM
  #95
joeyc125's Avatar
11 Second Truck Club
Iats are getting to you on the high boost pull, the low boost is pretty impressive! Try a high boost pull with some cooler iat's to start, looks like it was hot already.
Old Sep 11, 2011 | 08:38 PM
  #96
joeyc125's Avatar
Also, how are you figuring those a/f ratios? My wideband still reads 11.xx wot because it goes off lambda and calculates it to a/f for gasoline, if that makes sense.
Old Sep 11, 2011 | 08:45 PM
  #97
deion82's Avatar
My a/f ratio is off of the dominator ecu reading from the e85 fuel selection. The other a/f guage was reading off lambda but no datalog for that.
Old Sep 12, 2011 | 05:47 AM
  #98
joeyc125's Avatar
Sounds good as far as that goes anyway
Old Sep 12, 2011 | 07:54 AM
  #99
deion82's Avatar
Here's some dyno pulls. Most all data is on my ecu that's why not much data on these.
Attached Thumbnails 408 roots blower build-6psi-large-.jpg   408 roots blower build-9psi-large-.jpg   408 roots blower build-15psi-large-.jpg
Old Sep 12, 2011 | 08:07 AM
  #100
Atomic's Avatar
I have a gauge for that
600ftlbs by 3500rpm, gotta love blowers
