408 or 370 for F.I.
Old Dec 26, 2008 | 01:54 PM
thunderwagen's Avatar
Default 408 or 370 for F.I.
I'm getting ready to yank the motor and forge it out before I end up throwing chunks of pistons into the heads. I'm trying to decide if I want to go with a 370 or a 408 and what compression I am going to put it at. I'm thinking between 9.5 and 10:1 on compression. I will be using the AFR 225cc heads I have now and probably a different cam than the GT2-3 that is in there now.
I am going to leave the turbo on there with 3.5 dp and 4" exhaust. Any suggestions and experiences would be appreciated.
Old Dec 26, 2008 | 02:48 PM
L7 Sierra's Avatar
I would go with the 370 becouse I have been reading the deck heigth on a LS is not suitable for a 408 if you want it to last a long time. The piston apparently partially comes out of the bottom of the block which kills the bore sealing thus effects life span. This was in a issue of car craft if you wanna look it up.
As for static compression ratio it depends on total boost you wanna run, but I would probily go with 9-1cr so I can run double digit boost easy.
Old Dec 26, 2008 | 02:56 PM
XLR8NSS's Avatar
Adkoonerstrator
I'd go with the 370 and just turn the boost up.
Backpressure seems to be a big issue with big cubic inch engines and smaller(relative) sized single setups. Put a T88 sized turbo on the 370 and let it eat!!
Old Dec 26, 2008 | 02:58 PM
Mangled03gmc's Avatar
Baltimore Whore
John
Old Dec 26, 2008 | 03:00 PM
03sierraslt's Avatar
YAAA.... +1 to that.
Old Dec 26, 2008 | 03:20 PM
MikeGyver's Avatar
I love the torque that my 408 has. I would have been happy if I just forged my 6.0 with the heads, cam, and intake. I would like to have back the mpg that I lost.
Old Dec 26, 2008 | 05:02 PM
1BADAZZSS's Avatar
I am just goin to be building a forged 370 this year. Nice thing is it will be cheaper to build than a 408. You can use the stock crank from a 6L which from what I heard and read up on the stock cranks are good to 1000hp which I wont be coming close to that. And price for machine work would be more on a 408. I figured a forged 370 with some stock l92 heads,intake and custom cam should put down some decent power for what I am wanting to do. Thats the plan for right now anyways lol
Old Dec 26, 2008 | 05:27 PM
BlownChevy's Avatar
blownerator
25 Year Member
370 and wick that ****** up! Less Cubes, more boost! DOIT
Old Dec 26, 2008 | 05:34 PM
Its going to be mostly street duty, and gas mileage isnt really anything im concerned with on it, cause it only gets 12 now. Thats why I bought the pos rice burner for daily use. I really dont see myself going over 600- 700 rwhp with it, and want driveability. But it would be nice to be able to turn up the wick and get retarded with it.
Old Dec 26, 2008 | 06:01 PM
cablebandit's Avatar
9 Second Club
408 12 psi...9.59 @ 12psi.....4000# 10.3/4 cr
