4" race intercooler transmission cooler???
Old Feb 17, 2017 | 09:07 PM
Go5.3tt06's Avatar
Default 4" race intercooler transmission cooler???
I have hard time to figure out where best mount transmission cooler because I put on 4" race core intercooler. Need a help if someone who had done with this. Send pics here.
Old Feb 17, 2017 | 10:07 PM
SDjeff619's Avatar
I haven't mounted my trans cooler yet but it's going just below the steel bumper but it's a SS bumper with a little more flow through the lower section. I'm also running a 4" IC behind the grill.
Old Feb 18, 2017 | 02:48 AM
LPCWS6's Avatar
I had mine mounted between the intercooler and the AC condenser but those 2 angle pieces of square tubing that go up to where hood latch is had to be cut and redone differently.
Old Feb 18, 2017 | 07:38 AM
Go5.3tt06's Avatar
Mine no room between ac to ic a frame core
Old Feb 18, 2017 | 09:05 AM
LPCWS6's Avatar
I had the same issue as you. I had a shop do mine and honestly I haven't taken the cover off over the radiator to see exactly how they did it but this is what I told them to do and it's where my trans cooler is now.
I took one of the pics you posted and drew some stuff on it to explain. Where the red lines are I told them to cut those out. Then where green lines are I told them to weld in some new tubing to tie everything back together. inside that new green rectangle is where my truecool is.
Attached Thumbnails 4" race intercooler transmission cooler???-img_6950_422e6923187c34c87c5408f2dbeccf2ebc6080a0.jpg
Old Feb 18, 2017 | 09:15 AM
Go5.3tt06's Avatar
This morning I took bumper off. That look funny how I mount transmission cooler
Old Feb 18, 2017 | 09:18 AM
Go5.3tt06's Avatar
Exactly what Rick tried to tell me. I could weld it but have to take off and bring to my work suck. They are aluminum
Old Feb 18, 2017 | 09:38 AM
TrickTurbo's Avatar
Truck Sponsor
That is not what I explain was an option to do.
03-07 has Huges amount of room between core support and back side of bumper or grill.
We have installed a 6" core in ther with some trimming once grill installed you could not see trimming.
Old Feb 18, 2017 | 10:18 AM
MikeGyver's Avatar
I would not put anything that produces heat in front of the intercooler, an intercooler has a hard enough time using the ambient air temperature to cool the charge. Adding a trans cooler with 250° fluid in it will be counterproductive. If I was in your situation, I would put the cooler under the truck with electric fans.
Old Feb 18, 2017 | 10:24 AM
SDjeff619's Avatar
I didn't know you had the tall 4" IC. I agree with Mikegyver, mount it low with electric fan.
