4" Intake tubing
Old Apr 29, 2012 | 05:15 PM
  #31
Last Call's Avatar
TOTM: January 2007
Originally Posted by JimS
Where did you locate your battery? I like the heat wrap... it looks hairy.
Battery is underneath the bed on the drivers side.
Old Apr 29, 2012 | 05:20 PM
  #32
Last Call's Avatar
TOTM: January 2007
Or.. since the tuner is 50 miles away, I could build the new intake setup then reinstall the old one for the drive.
Now just have to build the intake, a new coolant resevoir, maybe a second heat exchanger, get the 2.6" and 10% od pulleys installed and I'm ready for the 2bar olsd tune, then maybe/probably nitrous and new injectors.
I still have that intake if you are interested...
I am really interested to see how your truck runs with a 2.6 and OD pulley, probably make about 15 psi. I think it will make a ton of torque, but get hot pretty quick. Your tuner will probably have to pull a timing with your IAT table to keep it from knocking.
Old Apr 29, 2012 | 05:24 PM
  #33
TIM Z's Avatar
11 sec. Truck Mod
Damn Jim your waist high in a pile of speed parts!!! SWEET!!!!!
Just wait till you feel that extra power, gonna punch ya right in the gut!!
The HEX that came in my kit is for the NNBS trucks, its larger than the OBS style . 03sierraSLT runs a CTS-V HEX i believe with his kit, Talk to Leftcoast Joe and he can hook you up with a larger HEX .
Old Apr 29, 2012 | 08:03 PM
  #34
JimS's Avatar
Thanks. I have a plan in my head for my intake or I'd take you up on your offer.... but just in case how about pm'ing me a price for it. I assume it's 4" tubing. Is it silicone or aluminum or ??
Old Apr 29, 2012 | 08:12 PM
  #35
JimS's Avatar
I have the larger coolant tank to install on the passengers side firewall and I have the pulleys, the puller and the pin kit.
As you can read here, I"m working on the intake.
I'm working on ideas for a second heat exchanger. Don't know where I'd put it... I can't picture how much room there is up under the shield in the front the rests under the radiator and protects the pan. What locations do others use?
Old Apr 30, 2012 | 09:13 AM
  #36
Last Call's Avatar
TOTM: January 2007
If you get an HD valance which has an oval opening, you can mount the heat exchanger there. That is where I have my trans cooler.
lsxperformance
Apr 20, 2016 12:17 AM
AHelm3
Apr 8, 2016 07:51 AM
BlackGMC
Aug 17, 2015 07:07 PM
Ammadien
Jul 22, 2015 08:50 PM
