4.8 turbo set up
Old Feb 26, 2015 | 11:39 PM
ChevyBlake06's Avatar
Registered User
Default 4.8 turbo set up
This is my first thread to help me out a little, I currently have a 2006 Chevy Silverado RCLB 4.8 and I was wondering if I should do a swap to a 6.0 if I wanna turbo my truck. I'm looking for 400-450 rwhp and was wondering if I'd be able to get that out of my 4.8 or if I would have to swap a 6.0 in. Im on a budget so please help me out with the best route. Also what would you guys recommend for turbos? Thank you for your help
Old Feb 27, 2015 | 12:04 AM
FFDP's Avatar
That 4.8 could make 600-700 easy with a good enough turbo/motor setup.
So keep the 4.8, slap a turbo kit on it and make an easy 400-500 horsepower.
Old Feb 27, 2015 | 04:20 AM
Badlands's Avatar
Agreed. Keep the 4.8 and do a good turbo. Maybe a small turbo cam and stall if you have the budget for it. 60lb or 80lb injectors and a fuel pump. Done. Easy power.
Old Feb 27, 2015 | 08:05 AM
Registered User
Where do you recommend I get a turbo system from? And would I have to upgrade any internals on the 4.8 to withstand the power im looking for?
Old Feb 27, 2015 | 10:46 AM
FFDP's Avatar
Your budget will come into play there.
On3 turbo kit is $2,000, plus the pump, injectors, other small odds and ends and you are up around $3,000+. KB racing/trickflow kits will be $3,500+ just for the kit.
And don't forget about the transmission, it might last a little while behind 400-500 whp but I'd say it will die sooner than you think.
Stock internals will handle that power, upgrade the valve springs would be a good idea though.
Old Feb 27, 2015 | 12:01 PM
Registered User
Do you think a 4l80e will hold up to 400-450 rwhp? And with the On3 turbo kit will 400-450 rwhp be achievable? Because that is my goal
Thanks for all your help
Old Feb 27, 2015 | 08:29 PM
FFDP's Avatar
Yes and yes.
A stock 80e with a shift kit will handle 400-500hp just fine.
The on3 kit with the cheapest turbo they make should support like 500hp, I think there website or the ebay ads they have say how much hp the turbo is good for.
Old Feb 27, 2015 | 09:12 PM
03chevytruck's Avatar
My goal is 600 Hp out of the on3 kit with their 70mm turbo. 4.8 with cam, meth, & how ever much psi it will give me!
Old Feb 27, 2015 | 09:44 PM
Blackrat48's Avatar
Well idk how to post pics on this site as a reply but my 4.8 turbo set up cost me about $3000..borg warner turbo, injectors,wg,bov,air to air,exhaust everything
I made all of it tho...just got it "done"
Let me know if you want details man
Old Feb 27, 2015 | 11:16 PM
Registered User
Im thinking I'm just gonna go with the On3 kit, it fits my budget perfectly and is very intriguing. Any comments on the On3 kit?
