4.8 60lb injector question
Old Mar 27, 2014 | 09:46 PM
Snowman007's Avatar
Registered User
Default 4.8 60lb injector question
I am getting parts together to turbo my 00 4.8 RCSB Silverado I found a great deal on some Siemens deka shorty style ev1 high impedance injectors will the work in my stock fuel rail and intake All i do know is I will have to change the injector plugs . thanks in advance
Old Apr 3, 2014 | 03:54 PM
1fastpickup's Avatar
I'm running them on mine...stock fuel rails with stock truck manifold. They will not seat out of the box. I had to cut down the tabs on the manifold to make them work.
I also bought the harness out of a Northstar Cadillac with it's plug (on the left) which had the right injector connectors so now I can just unplug the whole fuel harness at once.
Old Apr 3, 2014 | 07:11 PM
Snowman007's Avatar
Registered User
That's great thank you and great idea
Old Apr 3, 2014 | 11:01 PM
La Grey 1's Avatar
I'm more than sure i have the same injectors as you just buy the ev6 injector connectors online i bought mine at ebay for @ $10-12 and they have worked good for me... but what i did instead of cutting the intake use a piece of fuel/trans line and cut a little piece for each fuel rail bolt to use as a spacer for the fuel rails and buy the bolts a little longer...
Choda
Jan 22, 2026 02:03 PM
USMCvet0311
Aug 1, 2015 07:45 AM
MS3Z
Jul 30, 2015 06:17 PM
bbowerman
Jul 26, 2015 10:57 PM
