4.0 pulley
Old Apr 21, 2010 | 08:20 PM
5.3 GMC's Avatar
Default 4.0 pulley
On a p-1 a 4.0 pulley is supposed to make 8-9 psi? So around what size would I need to make 13-14 psi?
Old Apr 22, 2010 | 09:57 AM
Superado's Avatar
11 Second Truck Club
the first question would be ARE YOU MAKING 8 -9 with the 4.0" pulley...then go from there...it is dependent on your specific set-up...I made more than that w/ a 4.0"...the smaller the pulley you go with the more you will have to look at remedies for belt slip as well...
Old Apr 22, 2010 | 02:57 PM
5.3 GMC's Avatar
8 psi is what it's making. It is a 6 rib system so I'm sure belt slip plays a major role.
Old Apr 22, 2010 | 03:02 PM
Superado's Avatar
If you haven't already done so, you should look at repositioning your idlers for more belt wrap on the ProCharger pulley. I also think that I eliminated alot of belt slip and/or shock by going with a MUCH larger tensioner pulley. I attempted to go from a 4.0" to a 3.4" and grenaded my high mileage P1SC a couple of years ago.
Old Apr 22, 2010 | 03:03 PM
sharpshooter's Avatar
what are your cam specs?what rpm do you shift at?
Old Apr 22, 2010 | 04:58 PM
5.3 GMC's Avatar
220/220 .581/.581 112 may not be the best for boost but when I ran across the charger I couldn't really pass it up cuz of the deal I got. Shifts at 61-6200
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
Justin87gn
Sep 10, 2015 12:06 PM
