370 ready to fire or not
Old May 22, 2014 | 10:48 PM
tim wellington's Avatar
Default 370 ready to fire or not
I know this electrical but I need help .ready to start engine .but no fuel pump activity or spark at plugs .battery has disconnected since 3/26/14 .only different on outside of engine is painted valve covers.fuel pump runs if I jumped it at prime spot in fuse box.
Old May 22, 2014 | 11:01 PM
FFDP's Avatar
Missing a ground?
Old May 23, 2014 | 08:15 AM
BigKID's Avatar
Cam and crank sensors plugged in? Does the fuel pump prime with key on?
Old May 23, 2014 | 08:22 AM
Atomic's Avatar
I have a gauge for that
Any blown fuses?
Old May 23, 2014 | 09:59 AM
Gadgetized's Avatar
Another member once had similar issues and it was problems with the tune loading. He was using Autocal from Blackbear. They ended up getting him straightened out.
Old May 23, 2014 | 05:04 PM
Default thanks
injector a / injector b fuse. fired right up 60lbs of pressure hot ,45 lbs hot .drove about fifty miles.runs fine just a little richer.waiting on 2 bar map sensor .getting rid of M.A.F TUNE .Going speed density with the help of my new friend.
Old May 23, 2014 | 08:16 PM
oakley6575's Avatar
There you go. Then beat on it till it pukes
Old May 23, 2014 | 08:31 PM
Atomic's Avatar
Nailed it!
00loudchevy
Dec 3, 2015 05:54 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
gmcyukon
Oct 3, 2015 11:03 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
Velocity1
Oct 2, 2015 08:01 AM
