View Poll Results: 347 or 370
347
13.04%
370
86.96%
Voters: 69. You may not vote on this poll
347 or 370
Old May 7, 2010 | 10:43 PM
  #31
regcabls6's Avatar
4.8 crank .060 over on lq4/9 block. then spin the **** out of it. should be close to a 6.0 again.
Old May 7, 2010 | 11:56 PM
  #32
1Bear's Avatar
Even at 0.060" over, it would come up a little shy of being a 6.0L again. It would be 5.6L or 338ci, a good 26ci short. A safe 0.030" over would be only 5.5L or 333ci, but should make for one hell of a little screamer.
Old May 8, 2010 | 01:46 AM
  #33
Spoolin's Avatar
GFYS and STFU
Originally Posted by 1Bear
One of the major reasons someone would stay with a 347 even when building their aluminum block is that outside of stroking the hell out of one or re-sleeving the block, due to only being able to bore one out 0.010” to 0.020” depending on the year of the block, they are limited in what they can do. At least when someone throws a 4” stroke crank in a 6.0, you still end up with at least a square motor. Whereas stroking a 5.7 to a 383, you end up with a well under-square motor with a 3.905” bore x 4.00” stroke or a 384 if you went with a 3.910” bore. Then to top it off, you’re limited on valve size with the relatively small bore sizes. I feel that most folks would just rather keep their money in their pockets and keep a happy good revving motor or take the plunge and move up to another block entirely.
That's what I was waiting to hear!!
Old May 8, 2010 | 07:49 PM
  #34
10 Second Truck Club
go for a hke 370 fool, so i can get one too
Old May 9, 2010 | 10:03 PM
  #35
Most Hated's Avatar
thats my master plan
Old May 9, 2010 | 10:42 PM
  #36
MikeGyver's Avatar
With everything else remaining the same, the smaller the bore the less prone to detonation a motor is.
Old May 10, 2010 | 02:25 AM
  #37
Spoolin's Avatar
GFYS and STFU
Thanks Yoda!!
Old May 10, 2010 | 09:20 AM
  #38
sprayedenali's Avatar
THIS!!!
CI doesnt necassarily matter as much with boost. so build a small, high revving motor and put 20psi to it!!!
Old May 10, 2010 | 01:50 PM
  #39
Most Hated's Avatar
whats a good cr for boost on a 370 ? for lets say 20-23 psi
Old May 10, 2010 | 04:03 PM
  #40
Spoolin's Avatar
GFYS and STFU
For that much boost I would stay below 9:1
