View Poll Results: 347 or 370
347
13.04%
370
86.96%
Voters: 69. You may not vote on this poll
347 or 370
Old May 6, 2010 | 08:08 PM
Llaverito's Avatar
or u can buy my 4.8, its a proven lil engine. Or the 364 I have at the shop for boooost
Old May 6, 2010 | 08:19 PM
pewterliftedz's Avatar
my vote is 370 and upgrade that lil 76 to a 88 lol...
Old May 6, 2010 | 10:03 PM
Most Hated's Avatar
Originally Posted by stock48
Bigger is not ALLWAYS better. Many times a 76mm turbo will make more power on 346CI or less.
thats what im thinking but a friend told me that a 370 will make the same power with less boost than a 347 with more boost
Old May 6, 2010 | 10:32 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
are you basing engine size around a given form of FI? That's not the same question now is it?
Old May 6, 2010 | 10:36 PM
fastrt's Avatar
11 Second Truck Club
370 ftw!!
Old May 6, 2010 | 11:10 PM
Most Hated's Avatar
lets say for examp the both motor have an 76mm with 15 psi which will have more power
Old May 7, 2010 | 10:43 AM
kbracing96's Avatar
The 370 of course, because you putting more air though it. 15psi of boost is only a measurement of restriction, not the amount of air being flowed by the motor. The point Stock48 was tying to make is to make the same power with a 347 as a 370, the turbo will have to make about 3 lbs or so MORE boost to make up the different in the amount of air the engine needs to consume to make X-power. In running the higher boost, say, 18psi on the 347 vs 15psi on a 370, may put the turbo in a better efficiency range then it is at 15 psi. Here is a general compressor map for a T76 to give you a better idea of what I'm talking about. See how as the pressure goes up, the turbo get more efficient for the amount of air its pumping?
Old May 7, 2010 | 11:41 AM
Most Hated's Avatar
370 it is then dam the poll is 1 sided lol
Old May 7, 2010 | 12:09 PM
just build the 370 and run the hell out of that t76.. gives you room to grow...
Old May 7, 2010 | 03:29 PM
Spoolin's Avatar
GFYS and STFU
What's the bore and stroke of a 347 out of curiosity?
