2013 5.3 RPM question
Old 04-04-2018, 10:27 AM
try'in2bfast's Avatar
Default 2013 5.3 RPM question
My setup is 5.3 with Procharger on 10psi. The question is how hard are you guys turning the same gen motor? I have with stock internals. Just wondering.
Old 04-04-2018, 04:29 PM
FFDP's Avatar
Without valve springs and running a stock cam I wouldn't even push it past 5,900-6,000. The camshaft doesn't make any extra power there.
Old 08-09-2018, 09:29 AM
Slapps74's Avatar
With the Texas Speed Stg # cam and that PSI I was twisting it to about 6600.
Old 08-09-2018, 08:01 PM
06 4.8's Avatar
Are you looking for every bit of ET or just playing around? If every bit of ET put a little better springs in it and spin it to 6400ish even with that stock cam. NO IT DOES NOT MAKE POWER up there but it keeps the rpms a little higher in the power band after the shift and doesn’t allow it to bog as much.
bu01
06-10-2015 11:38 AM
DaytonaTA
03-03-2015 12:11 PM
98tdi
09-05-2014 07:21 AM
L$X$10
03-03-2013 09:00 PM
L$X$10
03-03-2013 08:51 PM
Quick Reply: 2013 5.3 RPM question
