2 step off footbrake?
I know i can stand on a long bar i had attached to lugs with wife only pushing pedal down half way
Before with the twin setup i could turn the rear by my hand with pedal pushed all way to floor
You might want to try the SUV rear brakes first. They are a dual piston caliper and direct swap. Just get the rears for an 05 Tahoe. That's what I have on mine and they are very stout.
George is right the 2 step makes launching much more consistent.
No but they are a direct swap to the backing plate that normally comes on the 10b. I think they work fine with 16" wheels, really doubt 15s without grinding.
What size wheels are you using?
If you gain at least 0.1 in the 60ft by being able to brake boost harder, is that worth the 10lb or so for the bigger calipers? I would think so. What does 1 suv caliper weigh compared to 2 of the ones on the dual caliper setup?
