2 step off footbrake?
Old Dec 7, 2015 | 11:34 PM
GMCtrk's Avatar
I don't know what rear pads I have, whatever came with the calipers from Advance. I wonder if there's any extra clamping to be picked up with wagner pads?
Old Dec 7, 2015 | 11:37 PM
George C....'s Avatar
Formerly ScreamingL
I know i can stand on a long bar i had attached to lugs with wife only pushing pedal down half way
Before with the twin setup i could turn the rear by my hand with pedal pushed all way to floor
Old Dec 8, 2015 | 08:38 AM
Atomic's Avatar
I have a gauge for that
You might want to try the SUV rear brakes first. They are a dual piston caliper and direct swap. Just get the rears for an 05 Tahoe. That's what I have on mine and they are very stout.
George is right the 2 step makes launching much more consistent.
Old Dec 8, 2015 | 09:34 AM
Formerly ScreamingL
Suv arent a direct swap with the the 1320 brackets
Also will need alot of grinding and not sure how banjo is so may not clear bogarts
Old Dec 8, 2015 | 09:43 AM
Atomic's Avatar
No but they are a direct swap to the backing plate that normally comes on the 10b. I think they work fine with 16" wheels, really doubt 15s without grinding.
What size wheels are you using?
Old Dec 8, 2015 | 09:44 AM
Formerly ScreamingL
Correct as my crewcab has them
But then you gain weight going back to stock stuff
Old Dec 8, 2015 | 09:47 AM
Atomic's Avatar
If you gain at least 0.1 in the 60ft by being able to brake boost harder, is that worth the 10lb or so for the bigger calipers? I would think so. What does 1 suv caliper weigh compared to 2 of the ones on the dual caliper setup?
Old Dec 8, 2015 | 09:55 AM
Formerly ScreamingL
A front rotor is where ya drop weight
The billet caliper bracket drops weight
Dual caliper setup of 1320 is a failure
He needs a 2step and hell be fine
Old Dec 8, 2015 | 10:58 AM
GMCtrk's Avatar
Atomic, I'm sure you're aware the suv rears don't have a chance in hell of clearing my 15" wheels.
Old Dec 8, 2015 | 11:07 AM
Atomic's Avatar
Actually no, never messed with them and 15" wheels and I didn't know that's the size you were running (hence why I asked). Nevermind me then, continue on.
