2 bar map sensor
Old Jul 19, 2014 | 09:12 PM
cwalker2006's Avatar
Default 2 bar map sensor
Has anyone had problems with the sensor not reading right? Trying to tune my truck but the most kpas I can get out of it is 155ish. Not sure if the sensor is off or my gauge. My gauge is showing like 18lbs. No matter where I adjusted my boost controller the kpas stay the same. Could my controller be going bad? Or dis the sensor seem more logical
Old Jul 22, 2014 | 08:15 AM
GRRR65GTO's Avatar
Well if im not mistaken a 2 bar sensor is only good to 15 psi so that might be a problem
Old Jul 22, 2014 | 09:45 AM
I'm not sure if it was the way I was logging it or what. But I got it to read correctly now. Still under 15lbs. Is around 196ish kpas
Old Jul 26, 2014 | 12:41 PM
cpolaris502's Avatar
You have to go into your HPTuner tables and get rid of the map(sae) pid and add the 2bar map pid. (right click>insert)
is that the part that you missed? Also, is the KPA offset set properly in the tune?
natejk
Nov 15, 2016 08:05 AM
Tydriver
45
Oct 23, 2015 09:19 PM
chvy=power
Oct 20, 2015 09:08 AM
chopperloco
Sep 28, 2015 08:40 AM
TAPyvehc93
Sep 17, 2015 10:10 AM
