Kenne Belle 2.8 on 6.2 Truck, Accesory drive differences?
I am wanting to get away from Nitrous and Go FI. i am really stuck on the kenne bell 2.8 blower since it will give me room to grow with more boost in a new engine set up. I currently am running a GMPP 6.2 LS3/525hp in the truck right now on a 200 shot of nitrous. My question is, How do i go about putting this blower on my truck? i know that the firewall may need to be trimmed, and there is no kit that will utilize the truck accsesory drive, but is there a better way than switching my whole accessory drive to a new gen camaro accesory drive? if so, what parts\brackets need to be changed?
Thanks in advance
Thanks in advance
The Gen5 Camaro acc spacing is the same as the truck accs so since you already have rectangular port heads, you should be able to slap on a Camaro kit. You may have to get creative with the inlet as it is on the driver's side and is a bit larger than the previous C5 design. You may be able to flip the inlet and build a new bypass tube but the alternator may be in the way. If you want a direct bolt on twin-screw truck kit, look at Whipple.
GreyChevy
Jul 7, 2015 08:57 PM
