2.8" pulley belt upgrades...
Old Sep 6, 2010 | 12:53 PM
Atomic's Avatar
I have a gauge for that
Default 2.8" pulley belt upgrades...
I suppose I should have known this was coming running a 2.8" pulley
I threw the belt twice yesterday, and managed to break the stop on the tensioner,
The first time it actually got me out of a traffic ticket....tried out a 4wd launch from a light and didnt see the cop stop behind me
cop: "why were you squealing tires?"
me: "I didnt mean to. I cant stear, can I get out a take a look, I think something is broken"
Fortunately I found the belt off and blamed it on that
Anyway, the current belt is a 109.8" and I am moving to the gates 108" hd belt, 100mm idlers, and the HD tensioner. Basically everything I can do short of an 8 rib setup, which I see no need for.
I get around 7 pounds of boost at WOT with the 2.8" pulley btw.
Old Sep 6, 2010 | 06:13 PM
joeyc125's Avatar
11 Second Truck Club
I went through 2 of those tensioners due to that problem. I went to the shorter napa belt, seemed to help alot. And btw, think you can take out that bolt in the head for lifting the motor, less weight!
Old Sep 6, 2010 | 06:17 PM
wentbig's Avatar
I learned the hard way. It is the slack in the tensioner that lets the belt jump off.
If I belt to zero slack that is after you pry the belt on the tensioner is bottomed out, you will never jump a belt again. What happens is when you get in a dig and build boost the belt stretches a few inches then you bump the rev limiter or back-off fast and the belt shrinks a few inches. I know this sounds lame but I used to use a bungee at the track. I bet there is some other bungee guys out there.
Old Sep 6, 2010 | 06:47 PM
Atomic's Avatar
Yea, I know the problem is the belt stretching, but most guys dont get that problem until 10+ psi, I got lucky I guess.
Old Sep 7, 2010 | 06:27 PM
TIM Z's Avatar
11 sec. Truck Mod
Im running a 2.85 pulley and right now with my base tune am seeing 7psi also. ( just providng a lil info)
Any way I have the HD tensioner and crank pin kit from left coast joe, And my Belt is Tight as heck but goes on and ive had zero issues so far with belt throwing or " dust" or alignment.
Its a Dayco poly cog, I can go get the number if ya need it.
Old Sep 7, 2010 | 07:00 PM
Atomic's Avatar
I ordered the gates 108" hd belt, which people seem to like. The tune will not effect boost with a supercharger. I ordered the tensioner from magnacharger this morning, it seems to be cheaper to buy directly from them instead of their dealers...
Old Sep 7, 2010 | 07:58 PM
terravast4's Avatar
I have heard too much tension in the belt is hard on bearings on the idlers and tough on the blower snout....true???
Old Sep 7, 2010 | 08:00 PM
terravast4's Avatar
Fyi...I broke the magnacharger tensioner in like three months with a 2.8 pulley.
Old Sep 7, 2010 | 08:04 PM
TX Tahoe Z71's Avatar
The one in the kit or the HD tensioner? What size belt did you run and were you getting any belt slip?
Old Sep 7, 2010 | 08:06 PM
TIM Z's Avatar
11 sec. Truck Mod
yeah i know, that was just kinda for people who have been wanting numbers from my combo, dyno next week.
But anyway Please post how ya like the belt you ordered, I havent tried a gates belt .
So the Belt and tensioner broke just from a WOT launch? Or when you let off?
