2.5 bar map anyone?
Old May 21, 2013 | 06:33 PM
HIPSI's Avatar
Default 2.5 bar map anyone?
Anyone out there using this or is the 3 bar map more popular?
Old May 21, 2013 | 06:47 PM
topgun10x's Avatar
I'm using a 2.5 map for 12.75lbs
Old May 21, 2013 | 06:53 PM
HIPSI's Avatar
Did you get it from DSteck on hp tuners forum? What are you tuning with?
Old May 21, 2013 | 07:43 PM
blue0453's Avatar
3bar zr1 here. Works good. 15psi
Old May 22, 2013 | 10:39 AM
9 Second Club
ZR1 Map sensor for my 6.2 turbo. You can pulle sensor info right off hptuners.
Old May 22, 2013 | 01:29 PM
HIPSI's Avatar
Is The ZR1 a direct fit?
Old May 22, 2013 | 01:54 PM
topgun10x's Avatar
mine was tuned with Sniper.
Old May 22, 2013 | 08:40 PM
blue0453's Avatar
I left the stock map in place to keep hole plugged up. You will need the zr1 map sensor harness and will have to cut factort plug off and solder on new plug. I then used the pcv port on the intake with a piece of 3/8 tube about an 1" long then plugged new map onto that. I have the wiring schematic if you need it because the wiring order is different.
Old May 22, 2013 | 10:48 PM
9 Second Club
It was plug and play on my 2012 Sierra.
Old May 22, 2013 | 11:32 PM
foose04's Avatar
Tell me more!
Buy 3 bar zr1, harness, cut and solder.. Is it not the same size as the stock one? Why did you relocate?
What was done in the tune? With this work on a 04 and Hptuners?
Thanks for the info sir!
