1psi in the crankcase
Old Nov 4, 2007 | 11:01 AM
TG02Z71's Avatar
Originally Posted by parish8
i put a drivers side valve cover on the pasenger side and put a filter in the fill hole. no more pcv for me. nothing seemed to work and everything seemed to put oil where i didn't want it. breather is easy.
That's a great idea. Since I have an extra set of covers I will be doing the same, much bigger breathing hole then.
Old Nov 4, 2007 | 11:45 AM
moregrip's Avatar
what a rush!
I will be running my system through catch cans but I don't plan on running any pcv or check valves
Old Nov 4, 2007 | 11:48 AM
thunder550's Avatar
High on diesel fumes
Thanks for the pics Bill, I may have to have you build me a bracket I'll start gathering parts this week probably.
Good idea on the driver's side valve cover parish, I'll have to pick one up and do the same thing.
Thanks for the comments everyone, sounds like a PCV delete will be my next mod.
Old Nov 11, 2007 | 11:50 PM
Turbo 6.0's Avatar
Originally Posted by thunder550
I re-plumbed my boost gauge into the crankcase today, and saw under high RPM/high boost that I'm building about 1psi or so of pressure in the crankcase. Is that enough to push oil past the seals? I'm running a PCV setup right now, trying to determine if I should install a breather setup.
Have you thought about running a pan-e-vac system?
Old Nov 12, 2007 | 12:05 AM
thunder550's Avatar
What's that?
Old Nov 12, 2007 | 12:31 AM
kbracing96's Avatar
What's that?
Hooking up the thing that's welded in your down pipe to you crank case.
Old Nov 12, 2007 | 12:45 AM
thunder550's Avatar
Oh. Yeah, I've thought about it. I think I'm gonna try a hybrid PCV and breather type system.
Old Nov 13, 2007 | 07:18 AM
If you wanna do a breather setup what do you do with the line comming from the tb to valve cover and rear of the valve cover to the intake, do you just cap those off?????
Old Nov 13, 2007 | 04:46 PM
Mort's Avatar
Yes, if you want to do a straight breather set up, you cap off the lines from the
TB and Intake manifold to the valve covers.
Old Nov 17, 2007 | 06:10 PM
I have a sts setup and was wondering can you just get rid of that pcv vent solenoid thing?
