1psi in the crankcase
High on diesel fumes
Thanks for the pics Bill, I may have to have you build me a bracket
I'll start gathering parts this week probably.
Good idea on the driver's side valve cover parish, I'll have to pick one up and do the same thing.
Thanks for the comments everyone, sounds like a PCV delete will be my next mod.
I'll start gathering parts this week probably. Good idea on the driver's side valve cover parish, I'll have to pick one up and do the same thing.
I re-plumbed my boost gauge into the crankcase today, and saw under high RPM/high boost that I'm building about 1psi or so of pressure in the crankcase. Is that enough to push oil past the seals? I'm running a PCV setup right now, trying to determine if I should install a breather setup.
Have you thought about running a pan-e-vac system?
TB and Intake manifold to the valve covers.
