1k + rwhp SBE
Old Feb 1, 2018 | 12:40 PM
Burnett03's Avatar
Originally Posted by BigBlock90
I have a 6.0 in my truck with stock bore flat tops, gen 4 rods, ported 243 heads, small cam, nnbs intake, 102tb, fic1000 injectors and a billet wheel s480 turbo. I put down 879rwhp on 19psi and im fixin to go up a few pounds and see how close it will get to the 1000 mark.
I ran the time in my sig on 15psi so i hope the 19psi setting will improve that a fair bit.
Man you boys are making some power. What fuel, what timing?
Old Feb 1, 2018 | 12:42 PM
BigBlock90's Avatar
Pump 93 with 100% m1 in the boost cooler tank. I run 10 degrees of timing on my 15psi setting and 9 degrees on the 19psi.
Old Feb 1, 2018 | 05:38 PM
MrHorsepowerLSx's Avatar
11 Second Club
M1 FTW, I run a mix of 93 pump and C12, with no timing and little boost lol fixing to change all of that right shortly, as the last time at the dyno I was blowing through the converter something fierce, on like 9-10psi I was at 460whp/600ft. Lbs lmao more
Boost and more timing netted me the same power, so I’m looking to really turn up the wick on the next dyno session
Old Feb 2, 2018 | 11:01 AM
turboal1's Avatar
Default Dyno
MR, where do you go for your dyno tuning ?
Old Feb 2, 2018 | 11:28 AM
Vortec350ss's Avatar
I have never seen a blower make 1000 on a stock bottom end... Nor do I think I ever will with an LS.
Old Feb 2, 2018 | 11:54 AM
11 Second Club
I use Fonse Performance in Erial,NJ (sicklerville, if you look at the map lol)
lxcoupe
Feb 27, 2017 07:41 PM
03regcab sierra
Oct 10, 2016 10:22 AM
stock48
Jun 13, 2016 01:16 AM
kush killer
Feb 17, 2016 09:20 PM
Tuckin15s
Sep 23, 2015 09:35 PM
