112 mag. 90mm "J" tube
Old Nov 7, 2010 | 07:43 PM
DrX's Avatar
DrX
Originally Posted by DanszToy
the maguson rep claimed they don't make one for my 112. Could he be wrong or are they only availlable for the larger blowers. thanks. Dan
Don't know if it will make a difference if you say it is for the larger MP122.
Old Nov 7, 2010 | 08:14 PM
terravast4's Avatar
They had a small run of the 90mm j-tubes and then had a blow out sale to get rid of the leftovers. i got mine with a wiring adapter for cheap.
Old Nov 7, 2010 | 08:26 PM
DrX's Avatar
DrX
Looks like the 90mm flange did come standard on the MP122's.
Old Nov 7, 2010 | 08:29 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
90mm tube did come standard on 122s and last I heard you could buy the 90mm tubes directly from Magnacharger thats why Richard stopped making them.
Old Nov 7, 2010 | 08:31 PM
1Bear's Avatar
If you can’t find the J-Tube your looking for and don’t mind just a little bit of work, you can take the approach I have started along. Yes, you will still have to open up the end of the J-Tube to 90mm yourself and machine the adapter to the full size, but you can purchase a 90mm to 78mm adapter to mate the bolt patterns. You wouldn’t want to just bolt it on and go, as it would serve no purpose to have a restriction of over a ½” in the set-up, but outside the cutting/grinding it does become a bolt on affair.
Old Nov 7, 2010 | 09:15 PM
DanszToy's Avatar
Thanks all.
Old Nov 7, 2010 | 09:32 PM
Blownme's Avatar
So will the 122 j tube work on the 112?
Old Nov 7, 2010 | 10:36 PM
DrX's Avatar
DrX
MP112 and MP122 share the same dimensions on the inlet end according to the pdf catalog I'm looking at.
Old Nov 7, 2010 | 10:48 PM
loloone's Avatar
LS1Tech Editor
That would be b!tchin if I could mount the 90mm J-tube off the 122 on my 112!
Old Nov 11, 2010 | 06:36 PM
DanszToy's Avatar
Default 90mm "J" tube for maggie 112 & 122
I called magnuson products again . This time I asked for a 122 "J" tube (good idea!). They do have them ( $187.00) . Also confirmed that it fits a 112 blower. Mine is on its way & I'm curious to see if the intake runner is also larger. Dan
Pimpinpete
43
Dec 22, 2017 08:13 AM
Jake75
Oct 2, 2015 02:28 PM
Wolftrk99
Oct 2, 2015 08:17 AM
old motorhead
Sep 29, 2015 08:22 PM
Chevy305
Sep 28, 2015 09:21 PM
