10.1 on a blower?
Old Nov 23, 2007 | 03:40 PM
05crew's Avatar
Default 10.1 on a blower?
is a 10.1 comp. to much for a d1sc with about 13-15 psi on a forged 370? i was told that 9.1 or 9.5 would be best, but dont want it to fill dead out of boost, in a crew cab truck.
Old Nov 23, 2007 | 03:44 PM
2004SSS's Avatar
with methanol probably be ok , but is your fuel system able to handle it? a good tune will be needed but i think it is possible , i have the same setup but im running 9.25-1 cr with a vortech with the same amount of boost.
Old Nov 23, 2007 | 03:59 PM
03sierraslt's Avatar
The 44lb injectors wont handle it, at least not without allot of meth. Either way you cut it thats allot of boost for 10.1 and pump gas.
Old Nov 23, 2007 | 08:19 PM
Casey2323's Avatar
10:1 and boost will not be all that great because you cannot run much Timing advance Cylinder pressure will be Crazy high.. Unless u run tons of Meth... 10-13psi a stock 5.3 is under 9.5:1 .... If i was worried about Low end .. I would Watch my Cam choice ..and try and keep the stock converter
Old Nov 23, 2007 | 08:32 PM
kbracing96's Avatar
It would make for a great E-85 setup
Old Nov 23, 2007 | 09:07 PM
05crew's Avatar
65lbs inj. are going to be used. deck my heads and change the pistions to get 9.25 cr , talk to john at texas speed and he that was a easy fix.
calsdad
Jun 14, 2023 11:07 PM
bagged7104SS
Sep 24, 2015 08:42 PM
lxcoupe
Sep 22, 2015 02:50 PM
whippledstepside
Sep 17, 2015 05:02 AM
