07 silverado on3 turbo kit
#72
I pretty much did all of the "must have" items before.
A must is Trans, if yours is stock it will be junk in no time. Must do injectors, fuel pump and a good tuner. I Already had trans, drive line, axles, cam, lifters, springs and valves done before turbo install.
#73
#78
Ill PM you with info trans dudes info and a copy of my build sheet. remember that these trans are rated up to 500hp, in which I don't plan on changing my set up. if your gonna put down over that ya better do 80.
#79
well currently i have heads, cam, cai, headers (which are pointless at this point), and a torque converter, i havent done a dyno since im setting up the turbo this month but i have been looking into the 80 but honestly i think this will be the end of any other mods besides exterior, drivetrain, or suspension.
#80
so far so good, Everything worked great no mods really needed to make kit fit. keep in mind that first kits were for 99-06, so standard kit install I didn't fallow. But ill tell you that I only used 3/4s of cold side pipe they gave me. I turned cooler over with in and out up top and used my lower bumper holes with there bracket and it lined up. as far as turbo plenty of room around it. Only 1 hick up header pipe crossover hit spindle cup, chad and I are working that out now. Hands down its a really nice kit. Im shooting for dyno time before the 26th. Hurry up chad!!
I also ordered that dash logic from palmerperformance. thank god I don't have to butcher my dash!
What did you do to get around this issue? I am planning on buying this same kit and just want to know what I am going to have to deal with before it gets here
