07 silverado on3 turbo kit
Old 10-06-2014, 07:16 PM
  #71
53clos's Avatar
after you put the turbo what other upgrade was a must?
Old 10-06-2014, 08:30 PM
  #72
So.cal Wrk Sled's Avatar
I pretty much did all of the "must have" items before.
A must is Trans, if yours is stock it will be junk in no time. Must do injectors, fuel pump and a good tuner. I Already had trans, drive line, axles, cam, lifters, springs and valves done before turbo install.
Old 10-12-2014, 05:14 PM
  #73
53clos's Avatar
Sorry about the late reply, did you build your 4l60 or did you go with the 80e
Old 10-13-2014, 10:23 AM
  #74
I built the 60. Only because my trans guy told me he would make 60 work for me and gave me a warranty on it.
Old 10-13-2014, 12:11 PM
  #75
53clos's Avatar
would you recommend the shop you did the work at ? my turbo is in the mail and i just want to get everything done that i need to
Old 10-15-2014, 09:33 PM
  #76
are you talking trans or turbo crap?
Old 10-16-2014, 12:02 PM
  #77
53clos's Avatar
The trnasmision work i asked a couple people and they all gave me a hard time due to the turbo.
Old 10-17-2014, 03:33 PM
  #78
Ill PM you with info trans dudes info and a copy of my build sheet. remember that these trans are rated up to 500hp, in which I don't plan on changing my set up. if your gonna put down over that ya better do 80.
Old 10-18-2014, 11:21 AM
  #79
53clos's Avatar
well currently i have heads, cam, cai, headers (which are pointless at this point), and a torque converter, i havent done a dyno since im setting up the turbo this month but i have been looking into the 80 but honestly i think this will be the end of any other mods besides exterior, drivetrain, or suspension.
Old 06-23-2015, 02:17 PM
  #80
bigpimpdx's Avatar
so far so good, Everything worked great no mods really needed to make kit fit. keep in mind that first kits were for 99-06, so standard kit install I didn't fallow. But ill tell you that I only used 3/4s of cold side pipe they gave me. I turned cooler over with in and out up top and used my lower bumper holes with there bracket and it lined up. as far as turbo plenty of room around it. Only 1 hick up header pipe crossover hit spindle cup, chad and I are working that out now. Hands down its a really nice kit. Im shooting for dyno time before the 26th. Hurry up chad!!
I also ordered that dash logic from palmerperformance. thank god I don't have to butcher my dash!
What did you do to get around this issue? I am planning on buying this same kit and just want to know what I am going to have to deal with before it gets here
Quick Reply: 07 silverado on3 turbo kit
