07 Avalanche Water IC
Old Jul 14, 2007 | 11:34 PM
TrickTurbo's Avatar
Truck Sponsor
Default 07 Avalanche Water IC
Got to work on my truck a little bit. Working on both Water/Air and Air/Air intercoolers for this truck. The water intercooler has been almost finsihed for a some time. Been slammed on other projects, and could not work on mine, go figure.
Both intercoolers will be finalized and put to bed this coming week.
Water/Air core is 8x6x6. With 48 inches of air flow this unit will cover everything I will ever put to this truck.
2.5 inlet and 3.0 oulet.
Still need to build the water reserve tank, or fill tank, mount the heat exchanger and water pump. Unit will be using the Meziere water pump.
Truck will be on the road before August.
Complete kit with air to air will be just under 5000.00
Complete kit with air to water will be around 5400.00
Either should fit other 07 Chevy trucks.
Cheers.
Look really tight at the Altenator but there is about 3/4 of an inch.
More to come.
Rick
Old Jul 14, 2007 | 11:53 PM
1SlowHoe's Avatar
Destroyer of Transmissions
That AC line laying on the turbo housing doesnt concern you?
Old Jul 15, 2007 | 10:25 AM
TrickTurbo's Avatar
Truck Sponsor
Naw, its a bad angle there is plenty of room between the 2. There is a heat shield sleeve that goes over that hose and there is still room.
Old Jul 16, 2007 | 10:11 AM
FarmTruc's Avatar
Performance Trucks Sponsor
Looks good, can't wait to see it run!
You should be able to fit a huge heat exchanger in the front, behind the grill.
Make it as big as possible.
Does the system have a spot to dump some ice in it?
good work, these kits are very simple and make great power! IMO, it's the best kit available when you consider ease of installation and reliability, add to that, the most power of any charger out there!
later,
allen
Old Jul 16, 2007 | 10:38 AM
WJ MARK's Avatar
Lookin good!
Old Jul 16, 2007 | 04:35 PM
TrickTurbo's Avatar
Truck Sponsor
later,
allen
Thanks Allen, should be running this week. At least I hope I am. Yea heat exchanger going to be large for sure. The ICE tank is an interesting thing. Still wokring on its placement.
Talk to you soon, might be visiting again real soon.
Old Sep 17, 2007 | 10:45 PM
Any updates on this project?
What turned out better ? the a2a or a2w?
Old Sep 18, 2007 | 08:00 AM
TrickTurbo's Avatar
Truck Sponsor
non at this time. The truck had to go in to the dealer, had to remove all the turbo stuff, and have not put it back on yet. Been working on the R&D truck, going from stock to turbo.
I hope to get time to work on the Avalanche this winter.
Rick
Old Feb 12, 2008 | 07:21 AM
Any updates on the newbody style?
Old Feb 12, 2008 | 08:13 AM
TrickTurbo's Avatar
Truck Sponsor
We have the front mount kits done and have selling quite nicely.
Avalanche2002
Nov 30, 2015 07:31 AM
turbo6c3
Oct 5, 2015 06:11 PM
ice17
Sep 22, 2015 05:18 PM
whippledstepside
Sep 17, 2015 05:02 AM
FormulaZR
Sep 14, 2015 05:23 PM
