06 Silverado On3 Turbo Questions
#21
Naw man it wasnt that, i put a different 44mm wastgate on and it holds 8psi constant
Yea i had alot of ppl tell me about them but i figured i would try it anyways cuz i wanted to kinda do a full review on them, when i called for the scaling chart i was told there the same as sema deka 55's but they said FoMoCo on them and the part number came up as 42lb injectors at 43psi fuel pressure
a green top 42lb for injector are 48-49lb injectors at 58 base
#22
fact i think we made the most power from On3 parts
#23
Well you didnt have a problem stating that my wastgate wasnt correct sizing and that placement was wrong without even knowing anything about my setup, and thats great that it works for you but it failed on me and several other people after reading up on them, and it still doesnt excuse the fact that i can no longer reach them since i started having problems, but yes there kits do work, i changed a few parts that weren't working and its all good now
#24
#25
as for working alot of time its user error or installation, so have to base ppls issues of the owner when you first read up on these things
#27
Siemens Dekas are a good brand and are on the budget side, youd be fine with 60s but if you plan on going more boost go with 80s. I runs 80s in my truck and my tuner had no issues with them. I bought my set new off ebay
#29
You were planning on running e85 so id go with the 80s, and i think with a 76mm you should still be okay with a 44mm wastegate
#30
80's run out of steam fast on E85...I've seen too many 4.8's run out of injector with 80's on E85 when they weren't even running a crazy amount of boost.
Unfortunately if you want to run E85 (and it's awesome so if you can get reliably...go for it), you need to spend more on injectors.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
