06 Silverado On3 Turbo Questions
Old Apr 23, 2015 | 07:44 AM
Funkster's Avatar
12 Second Club
Originally Posted by ChevyBlake06
Yeah im wanting to use 80lb injectors with e85 and to run about 9-10 lbs of boost. Im hoping to get about 500 rwhp out of that to just be a street truck and to go down to the track on Friday nights and have fun with.
That setup should easily do 500rwhp. Honestly on 10lbs you will probably be in the 550rwhp range, depending on cam.
Old Apr 23, 2015 | 09:24 PM
ChevyBlake06's Avatar
Registered User
That's the range I'm looking for so that's good. What cam would you recommend I run?
Old Apr 24, 2015 | 12:08 AM
Funkster's Avatar
12 Second Club
I had a custom one spec'd. I recommend you do the same. Figure out what your setup is going to be entirely. Engine, Heads, Intake, Turbo, Rear, Tire, GEar, Trans, etc. then call someone like Lil John to have them spec you a cam. I am not sure if he still specs for people or not but Stock48 on here is pretty damn handy with cam specs as well.
Old Apr 24, 2015 | 12:24 AM
George C....'s Avatar
Formerly ScreamingL
Originally Posted by 08lambochevy
Yea dnt use there injectors or wastgate, Tial is a good replacement for that and i used Delphi 52's in mine, there direct plug and play to your stock injector plugs
Also dnt waste your money on there plug wires set
As someone who has made over 1000 rwhp with on3 gates....they do job just fine for budget builds
Old Apr 24, 2015 | 02:12 AM
Funkster's Avatar
12 Second Club
Ya, don't misunderstand. I had a TiAL gate already so I used it. I would be more concerned using a "cheaper" wastegate than say a BOV, but I wouldn't expect any issues with ON3 gates. I have torn one down for powder coating for a customer and have seen no issues or concerns internally.
Old Apr 24, 2015 | 09:18 AM
08lambochevy's Avatar
Well mine felt the need to spike 18#'s every time, took it apart and cleaned it, still 18#'s, and the same stuff has happened to other ppl as well, so maybe one out of every few is good, and there service sucks because i had no problem gettin them when i was installing with the kit but as soon as i got the wrong injectors with the wrong injector adapters($350 upgrade), and my gate messing up i can never get ahold of them or call back from them
Old Apr 24, 2015 | 09:53 AM
Funkster's Avatar
12 Second Club
Are you sure that wasn't a sizing issue with the wastegate?
For the record I wouldn't run their injectors. Fueling is not an area to cut corners.
Old Apr 24, 2015 | 10:15 AM
Formerly ScreamingL
So it's the gates fault for being sized wrong or incorrect placement
This is why the net is such a great place
Old Apr 24, 2015 | 12:02 PM
Yea a 44mm wastegate(comes with the kit) is the wrong size for a stock 4.8 with a 70mm turbo and being placed where they have it on there manifold must be wrong on my end too
Yea this net is a great place huh
Old Apr 24, 2015 | 12:12 PM
Naw man it wasnt that, i put a different 44mm wastgate on and it holds 8psi constant
Yea i had alot of ppl tell me about them but i figured i would try it anyways cuz i wanted to kinda do a full review on them, when i called for the scaling chart i was told there the same as sema deka 55's but they said FoMoCo on them and the part number came up as 42lb injectors at 43psi fuel pressure
