Mine was 2nd unlocked but in 3rd unlocked i did do 320/341 when I ran the 1/4
I didn't want to lock the 278mm base model Circle D.
You should have done a 3rd locked and your numbers would be alot higher. Why not lock the 278mm converter? It's got a bigger clutch then a smaller 9.5".
i agree. you are not locking it under wot, you are starting the run with it already locked, so it is not as hard on it.
Not worried about making big numbers. the 319hp is pretty accurate tho I think 341ft lbs is a bit high. I'm more worried about how well it'll move. Should find this out on Friday if all goes well this week.
When I ran at the track I ran consistent 14.4-14.5 at 94mph. 60ft time was killing me at a 2.45 best.
A lil more stall or a touch bigger cam and I'da gotten the 60ft down.
