Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Torque Build Results
Old Jan 24, 2014 | 02:31 PM
Duntov1967's Avatar
Default Torque Build Results
Engine Specifications:
Bore: 4.070” (Factory L92 aluminum block)
Stroke: 4” (Callies DragonSlayer)
Rods: 6.125” (Callies Ultra H-Beam)
Pistons: Manley #592770C-8 (-18cc dish), fitted with .170” wall wrist pins for boost application
Heads: Factory L-92, slight shave, dual valve springs (68cc chambers)
Head Gasket: Factory L92 (.051 thickness)
Compression Ratio: 9.8:1
Cam: Vinci Performance, DUR @ .050" 210* / 222*, LIFT .551 /.551, LSA 116* (.585 lift with 1.8 ratio rockers)
Rockers: Yella Terra 1.8 ratio adjustable
Throttle Body: 102mm Nick Williams DBW
MAF: Lingenfelter 100mm
Injectors: Siemen Deka #107962 (60 lbs/hr @39.15.psi)
Supercharger: Whipple 2.9L, 4" pulley, inter-cooled
Balancer: Innovators West 10% overdrive
Headers: ARH 1-3/4"
Vehicle:
2003 Suburban 2500 4X4
33" Tires on H2 Rims
4.10 Gears
Single 3.5" exhaust (GM Duramax muffler followed by a Walker resonator)
Going for more boost........... stay tuned!
Old Jan 24, 2014 | 04:57 PM
black00chev's Avatar
Slowest turbo build ever!
Damn that looks pretty fun right there! Id really like to see what it makes from 2k up.
Old Jan 24, 2014 | 07:05 PM
Razor's Avatar
BMF
What is the ignition timing?
What fuel?
Did you have to run a different accessory drive to get the 2.9 Whipple to fit? Assuming a 5th Gen Camaro kit?
Old Jan 24, 2014 | 07:20 PM
Duntov1967's Avatar
What fuel?
I think the tuner told me 31 degrees total. Edit: I don't know the timing!
Gas was 91 octane. No meth.
I ordered the 2010+ 2.9L Camaro tuner's kit. The Camaro uses the same drive dimensions as our trucks. You have the option of using the Camaro accessories or the truck ones. I use the truck one because I have Hydroboost brakes and modified the pwr steering/alternator bracket so it would rotate slightly towards the driver's side to clear the bypass and dbw TB.
Old Jan 24, 2014 | 08:28 PM
Ron@Vengeance's Avatar
LS1Tech Premium Sponsor
Originally Posted by Duntov1967
I think the tuner told me 31 degrees total. Gas was 91 octane. No meth.
Congrats on the #s John!! FWIW I just talked with Mike and your timing is NOWHERE near 31* under boost...
Old Jan 24, 2014 | 09:17 PM
03sierraslt's Avatar
I was going to say the same thing, no way its that high.
Old Jan 25, 2014 | 09:11 AM
Duntov1967's Avatar
Thanks for the correction. At my age I can't even remember what day it is. LOL This was my first boost motor so I am somewhat on unfamiliar ground.
I would like to add that my visit at Vengeance was a very positive one. The quality of work and the cleanliness of the shop that I saw really shows a high level of professionalism. Mike was awesome on the tune and shared his knowledge freely. I not only drove away with a great tune but also learned much.
Old Jan 25, 2014 | 10:04 AM
Razor's Avatar
BMF
Awesome, thanks for the info!
Old Jan 25, 2014 | 06:36 PM
oakley6575's Avatar
How much total boost do you want run?
Old Jan 28, 2014 | 12:53 PM
Duntov1967's Avatar
Just enough to get me in the 500 club for bragging rights. LOL Want to stay under 12 lbs. to keep it reliable and useable.
