Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Sdpc 5.3vvt dyno results
Old Feb 8, 2012 | 04:17 PM
  #21
Sales2@SDPC's Avatar
Trucks Sponsor
Originally Posted by gbody6liter
hell yes!! That's what i'm talking about. I'm getting that very cam for my truck. Mine is the same but ecsb and 3.42's.
hey buddy it was great to get to talk with you. I have sent you a pm with a quote to get that trucking moving a little faster.. :d
Old Feb 8, 2012 | 04:48 PM
  #22
pewterliftedz's Avatar
dang that 115 lopes... sounds dam good.
Old Feb 8, 2012 | 04:58 PM
  #23
Trucks Sponsor
Thank you that is idle at like 650 rpm and does great
Old Feb 9, 2012 | 06:32 PM
  #24
Gbody6liter's Avatar
Thanks a bunch bud. That quote, is that for a complete set of LS7 lifters? Also, what about some springs to go with it? Surely don't wanna use my cheesy *** oem springs with all those goodies inside. Do you have a p/n for the headers you have?
Old Feb 10, 2012 | 08:56 AM
  #25
Trucks Sponsor
thanks a bunch bud. That quote, is that for a complete set of ls7 lifters? Also, what about some springs to go with it? Surely don't wanna use my cheesy *** oem springs with all those goodies inside. Do you have a p/n for the headers you have?
yes that is for the full set of lifters. Sorry i did forget to include the springs. I just used the ls6 springs which are $56.95 set they work great i have had no issues. The headers are pacesetter part# psp72c2267.....
Old Feb 19, 2012 | 11:12 PM
  #26
ForcedTQ's Avatar
Originally Posted by NEGEN@SDPC
The nnbs style trucks already come with a 799 casting which is pretty much a ls2 head with the the bigger valve. So you take that big valve and cnc port then add a bigger cam you will lose alot of bottom end...... So knowing you have a 3.42 gear i would say dont do it, but if you change gear to like a 4.10 or 4.30 gear yes i would cnc my heads....
VALVE EVENTS. Say it with me, VALVE EVENTS. It all has to do with IVO, EVC, for charge air blow-thru/ exhaust reversion, and IVC for controlling dynamic compression. The port on his stage 2-3 head will have a bit to do with cylinder filing and the velocity of that port to resist intake charge reversal (cylinder intake "pressurization" when the piston is back on it's way up right before the valve closes. If the intake port velocity/pressure before IVC happens is not sufficient to keep the charge in the cylinder, yes torque in the lower rpm range will be lost. Since he already has the heads, it'd be best to have someone custom spec him a cam with the proper valve events to maximize the setup he currently has.
Old Sep 30, 2013 | 07:59 PM
  #27
TonyVette's Avatar
A little late to the party, but can I get a part# for that cam?
Looking for a vvt cam for my 2012 crew cab Colorado with the 5.3
Thanks!
P.S. What is the ICL on that cam? I want to take full advantage of the vvt, so I'm hoping it's something like 107-109.
$A_Money$81
Mar 27, 2023 10:25 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Lthompson
Oct 2, 2015 12:45 AM
jscherbs
Sep 30, 2015 07:54 AM
norris_83
Sep 9, 2015 04:14 PM
