Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
post up your boosted 4.8, 5.3, 6.0 number s
Old Mar 29, 2013 | 07:51 PM
  #51
turbo truck's Avatar
Default Just started
Just got started 09 silverado 2wd 5.3 3.73 e80 4l60e stock trams with cooler 7.5 lbs stock internals 397.8 hp and 565.4 tq need to get a decent wastegate to turn it up
Old Jul 15, 2013 | 08:00 PM
  #52
02chevyls1's Avatar
02 4x4 4l80 76mm ecsb 370ci
12lbs 525 rwhp
15lbs 110- 600 rwhp
Old Aug 21, 2013 | 11:25 AM
  #53
theheder's Avatar
Registered User
Tell us engine size 6.0 LS2 364ci
Engine mods cam, lifters, springs
Turbo, supercharged etc Procharger
Pounds of boost 8psi
Meth or not not
nos or not not
Trans, stall RPM level VI - YANK 3200
Tire size 255 50 20
601 RWHP on pump gas 93 octane
Old Nov 22, 2013 | 01:22 PM
  #54
LS1TRUCKGUY's Avatar
been a while since anyone posted in here.
5.3L
comp 212/218 low lift
ls9 head gaskets
Head studs
Trick stage 2 kit 70mm
No meth or nitrous
4l80e Circle D 2B multi disk
3:73 gears
295/45/20
465hp 477tq on 10lbs boost
Old Nov 22, 2013 | 02:34 PM
  #55
GMCtrk's Avatar
6.0L
222/226 113 lsa
Ls9 head gaskets/arp studs
E85 on a conservative tune
Stock 4l80e/stock converter
Full 4" exhaust
275/45/20 factory VHO wheels (72 lbs combined)
4.10 gears, clutch fan
S475 turbo T4 74mm turbine
542 rwhp @ 10 psi.
Trans has since blown up at 13.5 psi.
Old May 12, 2014 | 03:13 PM
  #56
Turbo09's Avatar
Tell us engine size 4.8
Engine mods, no
Turbo, T4 70mm trick stg 2
or 12psi
Meth or not not
nos or not not
Trans, 4L60, servos shift kit, max line pressure
Tire size 255 50 20
94 octane, 3" Dp to cut out
any gueses? im headed to the Dyno next week
Old May 12, 2014 | 05:18 PM
  #57
oakley6575's Avatar
578hp 547ftlbsTq
4.8L
Stock48 Triple 12, ARP Head Studs, ISKY Valve Springs, LS2 Timing Chain
S475 Cast with Race cover
12 psi
E85
4L80e w/ Yank SST 3200
28" ET Streets
Still kickin as of now. Most boost its seen is 14psi. Will be turning it up till it blows chunks
Old May 12, 2014 | 05:39 PM
  #58
smokeshow's Avatar
Mod with training wheels
578hp 547ftlbsTq
4.8L
12 psi
E85
28" ET Streets
Damn, mine only did 597 on 21psi with the 6.0. You guys make it look so easy.
Old May 12, 2014 | 05:43 PM
  #59
oakley6575's Avatar
Yea bullshit I remember seeing a 900hp dyno sheet out of that thing on less boost that 21psi
Old May 12, 2014 | 06:05 PM
  #60
smokeshow's Avatar
No srsly.
Turbo AWD Silverado on PSI's dyno. - YouTube
