Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Phoenix dyno results (thunder550, kbracing96, vanillagorilla)
Old Mar 5, 2006 | 01:14 AM
thunder550's Avatar
High on diesel fumes
Default Phoenix dyno results (thunder550, kbracing96, vanillagorilla)
Ok here's my results.....
Somewhere around 365 rwhp / 410 rwtq. Take a look at my AFR's....way way rich. I think she's got something close to 390 in her if I can get the tuning right.
Hopefully Kyle and Todd will post up shortly too.
Old Mar 5, 2006 | 12:35 PM
kbracing96's Avatar
Here's mine, Pretty happy with if for being a stock motor and only 7 lbs of boost. Although I need to find a load bearing dyno, as this dyno wouldn't load it hard enough tho build boost in the lower rpm as you can see in the graph. I thinh the funny thing in the graph is when the torque converter locked. Tune was pretty good (safe), EFILive showed A/F around 11.6-11.8 and was running about 17.5-18* of timing.
I'm getting a 02 Z06 cam and springs next week so I will have to see what that does to things . Should help ALOT on the top end.
Also, here is the EFILive screen shot of the run.
Old Mar 5, 2006 | 05:57 PM
vanillagorilla's Avatar
I had all my **** emailed to my work addy, so I'll post my abortion runs Monday!
Injectors go in VERY SOON!!!
Old Mar 5, 2006 | 06:45 PM
8ALTNG's Avatar
Vanilla~ What injectors are you running now???? how much did it make?????
Old Mar 5, 2006 | 11:26 PM
kbracing96's Avatar
There stock!!! Can you say running out of fuel at 4K...
Old Mar 6, 2006 | 12:00 AM
F8L Z71's Avatar
Ok, get the right parts and get back to the dyno. Both of you! *points to the dyno shop*
Hahaha
Old Mar 6, 2006 | 10:58 AM
Ok, so here's my 4th gear run where I hit the speed limiter at 120mph.
See if you can tell where I start to run of fuel.
363rwhp/392rwtq
Here's the EFI live screen shot. Thanks, Kyle! Do you think that AFR is bad? Hmmm.....
My other run was an abortion run in 3rd (6spd) so I wouldn't hit the limiter. This just resulted a lack of time for the turbo to build boost and another overly lean condition.
I will note that Phoenix gets some CRAZY air compared to Tucson. 77* with almost a 29 inHg baro is awesome compared to what I'm used to. I saw a hole 1psi more for some reason. That could account for some of the lean-ness, but then again maybe its the stock injectors and fuel pump.
I just basically wanted to see what the stock fuel system can do. I think we now know. Oh yeah, this is a mail order tune BTW.
Old Mar 6, 2006 | 01:24 PM
F8L Z71's Avatar
Damn you guys.. Get some fuel and correct tuning to those things. You have much more potential! LOL
Did you have fun though? Dyno days rule!
Old Mar 6, 2006 | 01:58 PM
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by vanillagorilla
Todd- 6969 E. Me St.
LOL
Old Mar 6, 2006 | 10:36 PM
kbracing96's Avatar
Hey!! My tune was spot on...(tuned by me, of course , not some high dollar mail order guy ) Just need some go fast parts and more boost.
It was a blast though!!
