Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
new dyno numbers on LA JOE GIBBS
Old Oct 26, 2011 | 12:23 AM
lablackbeast's Avatar
doesn't know what quit means
Default new dyno numbers on LA JOE GIBBS
la joe gibbs new numbers, did the 8 rib set up and gained 2 pounds and 90rwhp running out of fuel pump and of injector, still on the 60 pounders
thanks to flaco
Old Oct 26, 2011 | 01:47 AM
Spoolin's Avatar
GFYS and STFU
Great numbers!!! Whats the set-up again?
Old Oct 26, 2011 | 01:57 AM
08cheyennesc's Avatar
Great numbers , damn you were losing 2# in belt slippage , I will seriously consider going 8 rib now even though I have a P1.
Old Oct 26, 2011 | 01:58 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Looking good! How to the IAT's look at the end of a run on that F1?
Old Oct 26, 2011 | 03:24 AM
foose04's Avatar
And this guy talked about going to a 4.8l.... Blah blah blah, great numbers man. That is one mean dyno sheet and I'm sure one fun ride.
Old Oct 26, 2011 | 05:18 AM
blown02408's Avatar
02 w/ lowest mileage 2800
Great numbers
Old Oct 26, 2011 | 06:24 AM
sureshot's Avatar
Awesome numbers! How much boost are you running?
Old Oct 26, 2011 | 10:12 AM
The 2 extra pounds werent because I had belt slippage, it gained them because of the 10% overdrive crank pulley, I was going to start running e85 but we didnt have time to put the injectors or the the 4.0 pulley from reichard racing, and this is a 6.0 with f1a @ 16 psi
Old Oct 26, 2011 | 11:34 AM
sureshot's Avatar
What does your fueling system consist of? What kind of timing are you running?
Old Oct 26, 2011 | 11:47 AM
60# injectors and 2 255 intank walbros, this on 93 pump gas and no meth at all (which i dont have the kit anyways lol)
