Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
new dyno numbers on LA JOE GIBBS
Old Oct 26, 2011 | 11:52 AM
sureshot's Avatar
You wont need the meth if you go e85!
Old Oct 26, 2011 | 11:53 AM
lablackbeast's Avatar
doesn't know what quit means
i know i wont thats why i havent added it
Old Oct 26, 2011 | 12:14 PM
pewterliftedz's Avatar
whatinjectors ru planning on running with e85. 90s??
Old Oct 26, 2011 | 03:01 PM
sharpshooter's Avatar
nice!
How much timing was in that pull?
Old Oct 26, 2011 | 07:12 PM
120 @ 43.5 psi and idk about the timing
Old Oct 26, 2011 | 07:46 PM
dlt76028's Avatar
big numbers bro. stock 6.0, or is it built?
Old Oct 27, 2011 | 05:59 AM
blown02408's Avatar
02 w/ lowest mileage 2800
what size blower pulley are you running?
Old Oct 27, 2011 | 11:54 PM
slowlsx's Avatar
i dont think your running out of pump but injector yes. new injectors and bigger feed line should do the trick. 2-255's are good for 1000whp if dont properly.
how much more power do you want to make lol it is a stock bottom end! im affraid of making anymore boost and im on 12 psi
Old Oct 27, 2011 | 11:59 PM
2doorfury's Avatar
well im sure if you set it up right you could do 25+ psi on stock bottom end..im sure everyone read the write up in hot rod a couple months back right??
Old Oct 28, 2011 | 12:08 AM
slowlsx's Avatar
engine dyno and real dyno are two different things. PSI is only a measure of restriction, he has cnc heads, good intake and a blower cam. he's making 760 at 16 psi so 25+ psi would be over 1000rwhp thru a stock bottom end? not gonna happen lol. switching over to E85 and 800rwhp and the motor will last a good bit.
