Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
LY6 TSP 231/236 still low dyno number
Old Dec 13, 2014 | 12:10 AM
  #21
Pro52R's Avatar
Stock L92 injectors? They are only like 33lb. I'd say you need more fuel. Idk though. I'm not a expert. Although it's depressing me, I'm afraid when I get mine done, I will make under 400.
I've seen some guys make 370wheel with full bolt ons.
Old Dec 13, 2014 | 11:16 AM
  #22
George C....'s Avatar
Formerly ScreamingL
Originally Posted by 81s
Ok Here's the rundown.
6.0 .015 over katech forged pistons and Arp rodbolts
823 heads lightly ported
Texas Speed 231/236 .641 .631 113lsa
Prc 650s spring 7.4 pushrods
L92 intake factory inj nw 92mm cable tb
Circle d 3600 stall 4l80e trans
4" cold air with ls7 maf
4.10 gear
I dynoed today at 381.9 rwhp. Though id be around 450whp.. any ideas?
Oh head3rs are schnoenfeld lts and 3" with dynomax bullets and ultraflows
compression?
what size headers?
fuel used?
what size wheels and tires on the rear?
Old Dec 13, 2014 | 03:44 PM
  #23
81s's Avatar
81s
Originally Posted by ScreamingL
compression?
what size headers?
fuel used?
I believe the compression is around 10. Its Ls3/l92 undecked.
93 octane
x275 pro mickeys
headers are schnoenfeld swap headers. 1 3/4 3inch collector
Old Dec 13, 2014 | 03:47 PM
  #24
81s's Avatar
81s
Track results if I didnt post....
7.82@89.7 mph 1/8 mile
Old Dec 13, 2014 | 06:31 PM
  #25
Formerly ScreamingL
Headers are small for that head/motor combo
On a 6.0 I did...we went from a ls6 intake and tb, 13/4 headers with 2.75 y pipe into single 3"
To fast 102/102, 1 7/8 headers with dual 3" into single 4"
Dual 4" air intake and gained 60/60 thru a 4000 stalled auto
410/350 to 470/410
Old Dec 13, 2014 | 07:06 PM
  #26
smokeshow's Avatar
Mod with training wheels
I've seen a 50% difference in power dyno to dyno...take all dyno numbers with a block of salt...
Old Dec 15, 2014 | 08:03 AM
  #27
Gadgetized's Avatar
Like said above, don't be too concerned over numbers.
Do you know the timing? AFR? Is the converter locked? How high were they turning it? With that cam and heads you should really have to turn it to peak out the power.
Old Dec 16, 2014 | 11:59 AM
  #28
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
380rw through a stalled 4L80e w/ 4.10s.....that's not bad for a cam only 6.0L with L92 heads.
Manual LS3 Cars make 460ish rwhp with that same cam and they have much more compression that you do, and much less drive-train loss. I think your numbers are where they should be considering what you have.
If the numbers mean that much to you, get it on another dyno. If it feels strong and runs the numbers at the track, I wouldn't be concerned.
rednekferlife101
32
Jan 8, 2016 10:42 PM
Greatdivider
Sep 9, 2015 09:52 AM
dselby25
Aug 24, 2015 07:26 PM
Jake75
Aug 5, 2015 01:26 PM
Cowboy17
Jul 9, 2015 08:22 PM
