Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
ls6 cam in a 5.3
Old Feb 13, 2009 | 01:09 PM
Default ls6 cam in a 5.3
I have looked all over but, can't figure out what are the gains people are seeing with an ls6 cam n/a on a 5.3. I am just wondering if it would be worth the time to do or should I just save my money for a thunder racing cam. I am looking for a gain in power but still want to use my truck as a truck and don't want to have to use a stall bigger than 3000. Any info would be helpful.
Old Feb 13, 2009 | 01:34 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
on the 4.8 i think i read that it was something like 20-30 IIRC shouldn't be much more for the 5.3 if it's anything more at all
Old Feb 13, 2009 | 01:41 PM
D_reks{5.3}'s Avatar
i think its about 20rwhp in a 5.3..
Old Feb 13, 2009 | 02:17 PM
72chevelle6.0's Avatar
This has a dyno number that one of the sponsers did on LS1tech
https://ls1tech.com/forums/conversio...onversion.html
Old Feb 13, 2009 | 03:38 PM
That is impressive for what was done to that little 5.3!
Old Feb 13, 2009 | 03:49 PM
yeah I was going to run the LS6 cam but I ended up with a built trans with 3000 stall so I went to the TR224 insted
Old Feb 13, 2009 | 04:15 PM
That was my next option was the TR224 how do you like it?
Old Feb 13, 2009 | 04:19 PM
I like it a lot. I got the 224 on the 112 LSA I am still working out the tune but so far it is a bad *** cam.
Old Feb 13, 2009 | 04:25 PM
bluecajun5.3's Avatar
11 Second Truck Club
put it this way...
if you don't want to run any higher than a 3000 stall, then the biggest i think you should go would be the tr220. assuming this is in a rcsb.
Old Feb 13, 2009 | 05:51 PM
Originally Posted by bluecajun5.3
put it this way...
It is a rcsb I talked to you about it at a midnightmadness at no problem. What size is your cam?
