Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
dynoed the 6.0 with the 228r
Old Dec 14, 2009 | 05:39 PM
  #21
droppedchev's Avatar
i think with some 42s i will see alot more im also running the 317s on an lq4
Old Dec 14, 2009 | 05:40 PM
  #22
yeah i thought it was my guess before the dyno was like 380 390
Old Dec 14, 2009 | 05:41 PM
  #23
Mangled03gmc's Avatar
Baltimore Whore
Unless it is running out of injector now, 42's isn't going to help you in the hp department..
Old Dec 14, 2009 | 05:43 PM
  #24
if i go with 42lbs i wont be running out of injectors then
  #25
Baltimore Whore
Are you running out now??
Old Dec 14, 2009 | 05:45 PM
  #26
i would think so idk i havent checked there only stock my buddy had the same motor with a smaller cam and he was running like 108 so i would think so
Old Dec 14, 2009 | 05:52 PM
  #27
Baltimore Whore
Well ig you don't have a afr or logging it while your doing the pull you won't know..unless it leans up so bad it misfires..
Old Dec 14, 2009 | 05:53 PM
  #28
but even if it was my buddy only put down 389 out of a 408 with l92 heads and all that so i really do think the dyno was wrong
Old Dec 14, 2009 | 05:55 PM
  #29
it did lean out at the top its was like 12.6 then went to like 14 i dont have the sheet of the afr my buddy that does my tuning has it so it deff is running out and they did the pull in second gear to
Old Dec 14, 2009 | 06:32 PM
  #30
GMCtrk's Avatar
I bet a good dollar that your cam isn't installed straight up. It's probably advanced and it already has 4 degrees ground into it.
