Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
dyno #s after heads cam
Old Mar 31, 2008 | 05:05 PM
dlt76028's Avatar
Originally Posted by cmiller
i went to the track and it was very disapointing 14.7 at 93. i guess im doing gears or a stall in the future 3.42 just arent working. once i get to 3k rpm it just takes off but getting there takes too long
well i guess that proves dyno numbers don't mean anything at the track.. i still would have expected alot more i was running faster then that with my 4.8 and it had 245hp... no stall, no cam, stock heads....
Old Mar 31, 2008 | 10:43 PM
Richard@WCCH's Avatar
FormerVendor
Thanks for the update Chris.
A stall converter will make a big difference at the track. The gears will make a nice difference at the track and on the street. Do the gears first. Your gas mileage around town won't hurt so bad. Both the gears and the higher stall converter will allow the engine to operate in a higher rpm range where the cam and head work is designed to go. Your tach will see 600-700rpm more with the gear change. That's a big difference. Also, the gears are less expensive. I'm sure from a roll your truck pulls pretty hard. It's the standing start that hurts your 1/4 mile et's.
Keep us posted on your progress.
Good luck.
Richard
Old Apr 1, 2008 | 10:46 AM
06 TRed GTO's Avatar
I picked up .7 10th's in the 1/8mi when I installed my 3600 stall.
Old Apr 2, 2008 | 01:55 PM
stock48's Avatar
9 Second Truck Club
I would get the stall first if it was me. I think it will make more difference. Even with 4.56 gears your launch will still be soft with no stall. You need to get that engine into it's power range so it can tug against that gear. With the higher stall your rpm's wont drop near as much between shifts, and that will healp you too. Between a good verter, and 4.10's you should pick up a good second. What are your shift points set at?
Old Apr 2, 2008 | 09:37 PM
cmiller's Avatar
the truck shifts at 5800 RPMs or so. i was looking at the yank tt 3000 or 2600 for the stall
Old Apr 3, 2008 | 10:22 AM
silver-mod-o's Avatar
Hunt&Fisherator
upping the shift points will help as well... after the ****, it should fall back into the powerband better... shifting at 5800 is causing it to drop too low and lose whatever power it had.
Old Apr 3, 2008 | 03:09 PM
sickREDsierra's Avatar
yeah, after i ****, mine falls back into the powerband much better!!
JFWY damned typo's
Old Apr 3, 2008 | 04:46 PM
Hunt&Fisherator
JFWY damned typo's
I just saw that... LOL
Old Apr 3, 2008 | 04:48 PM
Wheatley's Avatar
Truck Sponsor
Good numbers man,keep it up
OHsixLS3
Dec 27, 2016 09:30 AM
ls2 dude
Jul 25, 2015 11:22 PM
chevy1224
Jul 13, 2015 07:50 AM
Aboss
Jul 9, 2015 10:28 AM
NuckenFuts
Jul 9, 2015 08:45 AM
