Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
dyno #s after heads cam
Old Mar 24, 2008 | 07:50 PM
cmiller's Avatar
Default dyno #s after heads cam
little blury pic was taken on my cell phone. 2004 rcsb with 5.3 made 327hp, 329tq to the wheels on a dynojet after tuned. i instaled a 208 cam and stock heads with bigger valves and milled .030, as well as pacesetters. i was very impressed with the numbers, im hoping for low 14's and if im lucky a 13.9track times should be coming soon. thanks WCCH
chris
Old Mar 24, 2008 | 08:07 PM
tarinitup's Avatar
9 Second Truck Club
goood numbers man. BTW what kind of bumper do you have? It looks really nice.
Old Mar 27, 2008 | 03:44 PM
cmiller's Avatar
thanks the bumper was on my old truck it was from AIM industrys, i dont recomend them, bad customer service, bumber was twisted and didnt line up....
Old Mar 27, 2008 | 06:47 PM
dlt76028's Avatar
very good numbers for the reg cab. if you get a stall and tires you should get low 13's
Old Mar 27, 2008 | 07:15 PM
joshua022's Avatar
with a 3k+ stall and slicks you should hit high 12s. there are a couple of guys doing that already but without any head work.
Old Mar 30, 2008 | 07:46 PM
cmiller's Avatar
i went to the track and it was very disapointing 14.7 at 93. i guess im doing gears or a stall in the future 3.42 just arent working. once i get to 3k rpm it just takes off but getting there takes too long
Old Mar 30, 2008 | 07:54 PM
TouchOfEvil04's Avatar
what cam did you put in the truck? it's hard to see the actual powerband cause it's just to small/blurry.
A good 3000 or better yet 3200 stall with some 4.10's will make that truck run like a raped ape man.
I'd say a very low 13 with those two added on or better.
Old Mar 30, 2008 | 08:06 PM
cmiller's Avatar
its a 208, im not sure how towing and a stall work together
Old Mar 31, 2008 | 02:31 AM
LMSeven's Avatar
From all I've heard, towing with a Yank TT2600/3000 is as good as stock.
Old Mar 31, 2008 | 02:43 AM
Get a yank TT3000 and you won't have any problems towing.
I ran a yank tt for a good year/year and a half loading the truck down almost everyday with ALOT of weight and it was never a problem.
Run a TT3000 with a nice little cooler...bout a 24,000 bui unit or so and you can go fast and tow too.
Also get some 4.10's along with it and towing will be a breeze.
