Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Dyno question.
Old Nov 14, 2008 | 08:40 AM
  #21
zippy's Avatar
At 13psi on a 6.0L, unless you have two 63mm turbo's, you're way out of turbo. The small turbo is why it peaked early. I'd say the mess after that is either valve float or an ignition problem. It is possible that the dyno rpm trigger was having issue's also.
Old Nov 14, 2008 | 11:37 AM
  #22
2ktransam's Avatar
I was thinking the same thing. I have a MPT70 on my 6.0L and I had to turn my boost controller all the way up to get 12.5-13psi. I might have to step up to a MPT76 next year.
Old Nov 14, 2008 | 12:26 PM
  #23
SpoolinChevy's Avatar
Hopefully there's no real problem and everything on the log's look good. I was looking at eventually upgrading turbo's but not this soon.
Old Nov 14, 2008 | 10:27 PM
  #24
zippy's Avatar
If I had to bet I'd say at the track you'd be quicker at 8-10psi than pushing that turbo hard. If you push the turbo real hard you'll get inconsistant flow as well as alot of heat from it. Unless it's a hybrid turbo I wouldn't go smaller than a 76mm on a 6.0L. Some of the hybrid turbo's are very impressive and can push the needed air with a smaller wheel. They are just very expensive.
Old Nov 15, 2008 | 04:44 PM
  #25
76mm is what i was thinking.I think i saw somewhere KB carries mp76's but I'm not totally sure. Do they still use the t4 flange? I was thinking 4" exhaust to go along with it, I'm not sure i could fit a 4" dp with that also. I ran 3 or 4 times earlier in the night at my regular 10-11#'s, but i let out at the end not knowing if they were going to let me keep running or not so i never got a good number at my original boost.
Old Mar 19, 2009 | 06:21 PM
  #26
Spoolin's Avatar
GFYS and STFU
You ever upgrade turbo?
Old Mar 19, 2009 | 06:32 PM
  #27
nonnieselman's Avatar
Kinda old post that frenchy dug up..
but it could be the dyno spark signal is pickup up noise?
Mine looked a lot worse than that graph until Josh hooked up the injector signal wire instead of the one that goes over the Spark plug wire.
Worked great after that..
Old Mar 19, 2009 | 06:38 PM
  #28
Spoolin's Avatar
GFYS and STFU
I'm trying to catch up man...can't you cut a brother a little slack?
Old Mar 19, 2009 | 06:39 PM
  #29
NOPE... i got some catching up to do also... :nunchuk1:
Old Mar 28, 2009 | 10:45 PM
  #30
Atomic's Avatar
I have a gauge for that
This is what spark retard looks like
$A_Money$81
Mar 27, 2023 10:25 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Lthompson
Oct 2, 2015 12:45 AM
jscherbs
Sep 30, 2015 07:54 AM
dantheman1540
Sep 18, 2015 03:03 AM
