Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
broke 500 rwhp
Old Aug 29, 2011 | 12:21 PM
Mangled03gmc's Avatar
Baltimore Whore
Damn nice numbers.. You still running the 221-112 lsa cam?? This was with the 70mm still?? Congrats either way..
Old Aug 29, 2011 | 03:46 PM
Steve-O-08's Avatar
very nice!
Old Aug 29, 2011 | 07:56 PM
black00chev's Avatar
Slowest turbo build ever!
Originally Posted by foose04
Great numbers man!! What turbo you running and what gear was you in?
Old Aug 30, 2011 | 06:42 PM
black4.8's Avatar
yes and yes. 4th gear pull w/5 speed. btw single 255 is maxed out. pressure was dropping a little on the last few pulls. looks like they are good to 500 rwhp. time for a fuel cell, better pump w/ return system i guess.
Old Aug 30, 2011 | 09:21 PM
foose04's Avatar
That 70 is coming on a little late for 4th gear, is it in a .96 housing? My 70mm in .81 housing had 15psi by 3500. Even the 76GTS .96 a/r has 15psi at 4200. Could need a little more timing and a leaner a/f as well to get it up and going.
Also might want to pressure check the system for boost leaks.
Just some tips, either way it running pretty good!
Old Aug 31, 2011 | 05:07 AM
black4.8's Avatar
.81 but i'd say the cam i'm using is causing some of that, not best turbo cam. 16* timing right now
Old Nov 1, 2011 | 12:05 PM
JankesGTO's Avatar
500hp always feels good!
lukn4trbl355
Oct 21, 2015 11:19 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Velocity1
Oct 2, 2015 08:01 AM
Wrecker 426
Sep 30, 2015 09:39 PM
