Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
223/228 400rwhp through an 80E
Old Sep 4, 2007 | 08:12 AM
LIL SS's Avatar
Default 223/228 400rwhp through an 80E
Here is where I am at 347ci with stock LS6 heads, Stock pulley, stock 78mm TB. https://www.performancetrucks.net/fo...d.php?t=398925
Parts I am adding:
ABS stage 2.5 heads (Used with 3,200 miles)
Ported TB
UD pulley
9" 3200rpm fuddle verter
Parts should be in by the time I get back from my honeymoon. Anyone think I will pick up 39rwhp?? I think it will be close. Either way, it'll be faster Thing is lazy out of the hole with the stock verter, but fast enough to only loose by 1 link to a 13.0@110 F-bod.
Old Sep 4, 2007 | 03:08 PM
99Silverado5.3's Avatar
What block is that?
Looks like 360rwhp to me ..
Old Sep 4, 2007 | 03:29 PM
IMD's Avatar
IMD
Banned
so it makes 360 now...with stock cam and stock ls6 heads? if so, yes, you ought to be real close to 400 with those heads and upgraded cam. and of course a good tune to make it all work together. you ought to see good torque as well. thats a good cam for a truck.
Old Sep 5, 2007 | 03:28 PM
whitesilvy04's Avatar
IMO: I think the cam, pulleys and a tune would push you to that 400 marker...
Old Sep 5, 2007 | 06:07 PM
LIL SS's Avatar
I have the 223/228 right now and that dyno is tuned. I'm hoping to pick up 39rwhp with the pulley, Ported TB, heads, 9" converter and oil change.
Old Sep 5, 2007 | 06:34 PM
TouchOfEvil04's Avatar
You do know a looser converter like that fuddle vs your stock one will show lower numbers right?
Well i say like that fuddle but in reality any converter other than stock will lower your hp to the wheels on the ol dyno.
Old Sep 7, 2007 | 06:22 PM
LIL SS's Avatar
I agree if the converters are both the same size/weight. My thought is that a 9" verter will weigh much less and even though it is looser, once locked the rotating mass change might help or be equal on the final numbers. The stock verter in an 80E is like 12-13" and has got to weigh 50-55lbs.
I could be completely wrong, but I know a lighter flywheel set up or light rear wheels/tires have the same effect.
I'm more banking on the heads/ported TB to bring my numbers up. But I guess we will see when I get back from my honeymoon.
Wrecker 426
Sep 30, 2015 09:39 PM
mitchellmade
Sep 27, 2015 08:27 PM
01silvy
Sep 26, 2015 10:20 PM
trxmxzx
Sep 24, 2015 09:29 PM
trxmxzx
Sep 23, 2015 09:15 PM
