Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
07 denali 1/4 mile results
Old Jan 3, 2010 | 05:07 AM
wot_denali's Avatar
Default 07 denali 1/4 mile results
Today i took my car for 1/4 mile test i used the superchips to do this test with my 22" rims ,i got 95 mph 14.9 seconds ,my ?? is do big rims effects on the 1/4 run times .
Old Jan 3, 2010 | 09:58 AM
03sierraslt's Avatar
Yes they make it slower.
Old Jan 3, 2010 | 10:16 AM
outlawz2004's Avatar
I dont know how accurate the superchips are but at least its a good device to check if mods made a difference.The wheels will slow you down. If it is accurate, which I dont think it is compared to some dodge guys I know thats using them compared to track times, you mph is good for a low 14 second pass.
Old Jan 3, 2010 | 11:02 AM
jdustu's Avatar
The taller wheel/tire combo lowers your gearing and the added rotational weight hurts you as well.
Old Jan 3, 2010 | 02:32 PM
wot_denali's Avatar
My brother has a 20" oem rims i will swap with him and do the test again
Old Jan 4, 2010 | 11:04 AM
jdustu's Avatar
It depends on the tires too. The stock tires on the 22" srt10 rims are lower profile than my stock 20" tires, enough so that there really isn't much of an overall height difference. But the 17" combo is over an inch shorter, and to top it off the wheels weigh 10lbs less each. You'd have to look at the details closer rather than just 22s versus 20s.
Old Jan 15, 2010 | 02:52 PM
iamkeniff's Avatar
my 5.3/60E CCSB went 14.83 @ 94.01
get a custom tune an you'll be a lot happier imo
Old Jan 20, 2010 | 09:23 PM
KRestevan's Avatar
reducing weight on the wheels is the best option...each 1lb of rotational mass is about 7lbs in the bed of your truck..or in your backseat for ur yukon
Choda
Jan 22, 2026 02:03 PM
Oobray
Jun 13, 2022 03:38 AM
GXPJAY
Feb 13, 2022 08:15 AM
Bluchevypick
Aug 8, 2015 10:35 AM
fcompean
Jul 15, 2015 09:55 PM
