Weighed the A/C system tonight...
I got the A/C system off my truck tonight. Everything that is under the hood....3 lines, compressor w/bracket, condenser, canister w/bracket. Including the bolts the entire system weighed 28.8 lbs.
Just thought I would share the tech info.
Me too, I would have thought it weighed more. You could always add the few pounds of refrigerant as well.
I considered dropping it when I swapped my motor mostly to clean up the motor a bit. I hardly use it anyway.
I removed mine but it needed a $100 Dollar line to work so off it came. Otherwise I would have went on a 30 lb diet before taking it off my truck. I also don't drive my truck unless I want to or on the way to the track.
