TIME SLIP DATABASE
Turbo NNBS only running 12.7, help me out.
Old Feb 9, 2016 | 07:20 PM
  #41
GMCtrk's Avatar
Is the 1a tighter then they have listed on their website, or did you mean 1b?
Sorry I'm not trying to be a wise ***... I just looked to see how tight it was and its listed as 1b, but I know chris can play around with them a little.
mine is 1a, but it's the tightest as I'm aware. I'm not sure what's listed on their site, I go to the shop in person.
Any tighter would step up to 265 mm and they also have 5 disk lockup recommended over 1200 hp
Old Feb 9, 2016 | 07:21 PM
  #42
fastjweb's Avatar
Originally Posted by George C....
Ive ran a 110lsa before...lit off fast as hell
mine seems to aswell.
Old Feb 12, 2016 | 08:52 PM
  #43
TAPyvehc93's Avatar
So after talking to my instructor at school, that plan is to have my 799 heads CNC'd and I will be doing a valve job and milling the heads to bring the compression up to 10:1-10.5:1 (not exactly sure yet). I also am throwing the stock intake back on and I'll see what happens. If that doesn't help the next step is to swap out the cam. Should have the heads done with CNC next week.
Old Feb 12, 2016 | 09:21 PM
  #44
George C....'s Avatar
Formerly ScreamingL
Swap the cam..leave heads alone
Old Feb 13, 2016 | 10:09 PM
  #45
TAPyvehc93's Avatar
Whys that?? I am getting them CNC'd for free, can't pass that up. Its to easy to swap the cam out if its still not where I want it.
Old Feb 13, 2016 | 10:30 PM
  #46
Formerly ScreamingL
Sam student?
If heads are off may as well do cam
Old Feb 16, 2016 | 09:37 AM
  #47
madmann26's Avatar
Originally Posted by fastjweb
Not to hijack, but here are my cam specs, 214/218 .559/.563 111 LSA 109 ICL -6* Overlap, seems to work fine, but am I leaving alot on the table by not running at triple 12?
To elaborate a little on this for the OP,
The more overlap you have, ie, + numbers, the cam is less friendly to a boosted setup. Will it run? Sure. Will it work with boost? Sure. Is it ideal? No.
Most good FI cams will bias the exhaust side, some by ALOT.
Why does everyone keeping mentioning the triple 12? When you look at the specs on paper, you wouldn't think it would work but when you plug the numbers into a cam timer to look at valve events, it has -12 degrees of overlap.
The cam in my engine, which was put in as part of the longblock, has -8.0 degrees of overlap.
Just some thoughts for you. I would take the suggestions given. Ditch the hi-ram, get a stock truck intake, get a loser TC and do the triple 12 (since the heads will be off). That should work quite nicely together.
Remember, you have a heavy a$$ truck, not an f-body. You need to make power differently.
Old Feb 28, 2016 | 08:41 PM
  #48
Choda's Avatar
update?
Old Mar 2, 2016 | 07:05 PM
  #49
TAPyvehc93's Avatar
Originally Posted by Choda
update?
Still working on it, slowly but surely whenever I can. Got the heads back from CNC and I got my new Ferrea valves. The valve guides were pretty loose (.0025-.003) so I installed some K-liners and I am in the process of honing the guides. Next is the valves job and then I will be blending them all. I also still need to take some measurements and crunch some numbers to see how much I can mill off the heads. Also snagged me a used stock intake. I just need to buy some rails and make some brackets for them. I also wrapped my crossover pipe. The log manifold looks like a pain to wrap.
Old Mar 3, 2016 | 07:32 AM
  #50
Choda's Avatar
its really not, just take your time and do it nice the first time.
