TIME SLIP DATABASE
Turbo NNBS only running 12.7, help me out.
Old Feb 7, 2016 | 03:42 PM
  #21
George C....'s Avatar
Formerly ScreamingL
Gmt900 and call it a day
Dont need a fast dont need a holley for your build
Old Feb 7, 2016 | 10:18 PM
  #22
TAPyvehc93's Avatar
I know it will make a difference but do you think it will make that big of a difference lol? What aftermarket rails will fit it?
Old Feb 7, 2016 | 10:43 PM
  #23
Formerly ScreamingL
Yes and a better suited cam
Contact stock48 and grab one of his triple 12s
Should be able to make any rails work
Old Feb 8, 2016 | 06:26 AM
  #24
Choda's Avatar
I have a very similar truck with way less more and run 12.8. You def need to get your short times down. What's weird is w a stock converter and a 70mm I could brake boost up to 10 psi.
Old Feb 8, 2016 | 12:24 PM
  #25
kazfan30's Avatar
George C is pretty much telling it the way it is... and i totally agree. Way too much cam and WAY too much intake for a truck... there is a reason why the triple 12 works and why i ran a 216/216 cam...Yes leaving on boost would help, possibly a new converter but i promise you if you swap that cam and intake you will enjoy that truck so much more.
Old Feb 8, 2016 | 01:15 PM
  #26
TAPyvehc93's Avatar
How the heck are you doing that?
Old Feb 8, 2016 | 03:51 PM
  #27
Vortec350ss's Avatar
With that cam NA you would want a heck of a lot more converter than that as well. The converter is too tight for the parts you have.
That said I dont think the converter is too tight for what your goals are. If it was me I would start with a smaller cam. That will help you build boost off the line and the intake may be less of a concern. While I agree with George on this one I think the cam is the larger contributor. As long as you're boosting the intake will be fine. A stocker would still probably do you better.
Old Feb 8, 2016 | 10:48 PM
  #28
TAPyvehc93's Avatar
If I'm going to do the cam and intake, I am actually considering doing the heads now too while I am there. If I were to get my 799 heads CNC (leaving the stock 2.00 valves) would you still say to go back to the stock intake?
Old Feb 8, 2016 | 10:57 PM
  #29
Formerly ScreamingL
Yes....theres a car that runs 8.0 in 1320 with a stock intake on a 364...stock48
Old Feb 8, 2016 | 11:12 PM
  #30
TAPyvehc93's Avatar
Alrighty. I'll try and snag one off eBay.
