TIME SLIP DATABASE
Turbo NNBS only running 12.7, help me out.
Old Feb 9, 2016 | 08:12 AM
  #31
Beatdown Z's Avatar
Laid Back
Originally Posted by George C....
Yes....theres a car that runs 8.0 in 1320 with a stock intake on a 364...stock48
And that's with the older GMT800 intake, lol. That car is a beast
Old Feb 9, 2016 | 11:14 AM
  #32
Choda's Avatar
Originally Posted by TAPyvehc93
How the heck are you doing that?
put in 4x4.
put in 1st gear.
press brake firmly
put throttle to the floor.
it had no problem making boost. this was before my 3000 stall converter and before my 2 step. Stock trans, converter, engine...etc. I even have drum brakes in the back. The truck didnt move an inch.
Old Feb 9, 2016 | 11:34 AM
  #33
kbracing96's Avatar
Originally Posted by Choda
put in 4x4.
put in 1st gear.
press brake firmly
Kinda hard to put a 2wd truck in 4wd!
Old Feb 9, 2016 | 01:43 PM
  #34
GMCtrk's Avatar
If you put my setup in a light car, it would be capable of running 8s
No need for intakes or big cams
stock intake
triple 12 cam
circle d 1A converter (tightest they can build in 258)
Old Feb 9, 2016 | 02:39 PM
  #35
Vortec350ss's Avatar
Is the 1a tighter then they have listed on their website, or did you mean 1b?
Sorry I'm not trying to be a wise ***... I just looked to see how tight it was and its listed as 1b, but I know chris can play around with them a little.
Old Feb 9, 2016 | 05:10 PM
  #36
TAPyvehc93's Avatar
stock intake
triple 12 cam
Isn't a 112 LSA a little tight for boost??
Old Feb 9, 2016 | 05:34 PM
  #37
The LSA is all relative. The short answer is no.
The long answer is it depends what the valve events look like. His cam has very short duration, so he has less overlap than your cam with the 114 LSA.
Old Feb 9, 2016 | 05:45 PM
  #38
TAPyvehc93's Avatar
True True.
Old Feb 9, 2016 | 07:09 PM
  #39
fastjweb's Avatar
Not to hijack, but here are my cam specs, 214/218 .559/.563 111 LSA 109 ICL -6* Overlap, seems to work fine, but am I leaving alot on the table by not running at triple 12?
Old Feb 9, 2016 | 07:18 PM
  #40
George C....'s Avatar
Formerly ScreamingL
Ive ran a 110lsa before...lit off fast as hell
