TIME SLIP DATABASE
Turbo NNBS only running 12.7, help me out.
Old Feb 6, 2016 | 05:13 PM
ZO6Ted's Avatar
Try this. I used to build full boost on my 07 like this. From a stop put it in neutral then let off the brake. Give it a pretty healthy rev, let off and then jam the brake. Now put it in gear and see how much you can build. I could leave at 4400 if I wanted on a 3k converter with disc brakes. Good luck!
Old Feb 6, 2016 | 05:56 PM
George C....'s Avatar
Formerly ScreamingL
Originally Posted by 06 4.8
Your pats cousin right? If I remember isn't your cam on a 112 lsa? Def a little tight for a turbo setup.
I know of quite a few outstanding performing turbo cams on a 112lsa
Old Feb 6, 2016 | 06:19 PM
TAPyvehc93's Avatar
Haha yes I am. It's a 114 LSA
fastjweb's Avatar
my cam is on a 111 lsa. I think if the truck made alot more power it could handle a 3.42 gear. I would think it would still be faster with a 390-4.10 gear. My converter is built for my turbo set up. 3500 ptc, built with a nitrous stator so I can build boost at the line, but then it tightens up real quick. about 6% slip. Hydroboost would def help you out too.
Old Feb 6, 2016 | 10:32 PM
TAPyvehc93's Avatar
Would a two step and the hydro boost conversion alone help me get boost off the line even with the small converter and oversized intake and cam??
Old Feb 6, 2016 | 10:36 PM
Formerly ScreamingL
Intake is costing you so much down low
That cam is wrong for such a heavier truck
Even if you do more boost on launch truck will still be a dog thru most of run
Old Feb 7, 2016 | 05:02 AM
06 4.8's Avatar
Shows how much I know about turbo cams.lol
Def listen to the 2 above, not me
Old Feb 7, 2016 | 01:04 PM
TAPyvehc93's Avatar
Wahh!! It just sucks because I really don't wana buy a FAST because they are so $$$, and I already had two stock intakes that where blowing smoke at the seams when smoke tested.
Old Feb 7, 2016 | 01:15 PM
06 4.8's Avatar
I don't get that part... I know quite a few local guys and several TBSS pushing 15+ psi through those intakes
Old Feb 7, 2016 | 03:19 PM
TAPyvehc93's Avatar
I know, that's what I hear. Mabye nobody has ever had them smoke tested and maybe it's not leaking enough to make a difference but I did have two that leaked at the seems and one being brand new out of the box.
